Local Time 12:07 05 Nov 2026 Privacy Policy
Forum Index : Windmills : charge controller
guitarbaby
Posted: 09:51pm 05 Mar 2009
hello could someone tell me if i had windmill that puts out 400 watts say would you need a charge controller that would handle 400 watts thanks or how do you figure it out
niall1
Posted: 12:49am 06 Mar 2009
hi guitarbaby
its might be easier maybe to work it out thinking in volts and amps , not just the watts
if it was say a 24v mill rated at 400w thatd be about 16 amps of juice
it,d be good to pick a controller rated at a little higher wattage to give a bit of headroom..maybe one rated to controll 500w or 600w (about 20 amps or over ) at 24v
some more expensive controllers (often much higher wattage) can be pre set to work at different   voltages    which is nice if for some reason you change your mill
just a few thoughts
Edited by niall1 2009-03-07
niall
CraziestOzzy
Posted: 01:23am 06 Mar 2009
I would concur with niall1...think volts and amps. I would go 25% over for the protection
cheers
http://cr4.globalspec.com/member?u=25757
http://www.instructables.com/member/OzzyRoo/
guitarbaby
Posted: 02:43am 06 Mar 2009
thanks for your replys
Posted: 05:51am 23 Mar 2009
Repost of missing posts
guitarbaby wrote.....
hello i need help the controller i bought says you can divert the load to whatever you like say a heating element or whatever can somebody give me some ideas what or how to do this or maybe divert to another battery im just not sure what to do thanks
CraziestOzzy wrote.....
I always reckon that peltier units are a real great idea...several of them hooked up will freeze your beer nicely :)
Anyways, seriously - I am serious about the peltiers too - find out how much amps you expect to waste at what voltage and and then get the wire specs (length, diameter etc) to make your "heater element".
Don't ask me the exact specs as I will give you the minimum figures to fry eggs and bacon with
I assume your controller is appropriately fused and protected from your dump load...otherwise you might have rig some stuff up before you wire an element or something up.
