Local Time 12:12 05 Nov 2026 Privacy Policy
Forum Index : Windmills : blocking diod
guitarbaby
Posted: 11:23pm 14 Mar 2009
would any body know how to make a cheap blocking diod ro does a person just buy one
DaViD
Posted: 12:28am 15 Mar 2009
Spend a little money and buy you a Schlotzsky's diode
If your not living on the edge your taking up to much space!
CraziestOzzy
Posted: 05:41am 15 Mar 2009
Rip apart any old wall socket AC/DC transformer supply for an old mobile phone wall socket transformer (or similar old devices like toys etc that use mains power) that feels heavy compared to the newer types and you have four diodes in their busting their butts to be used :)
http://cr4.globalspec.com/member?u=25757
http://www.instructables.com/member/OzzyRoo/
woodchips
Posted: 05:55pm 15 Mar 2009
You do need to get one that can carry whatever amount of current you want to put through it. Matchhead epoxy ones are 1A, pea sized epoxy ones are 3A, then into the bolt down metal type. Old computer power supplies are a good source, most now look like rectangular power transistors, have to read the part number.
