Local Time 12:07 05 Nov 2026 Privacy Policy
Forum Index : Windmills : dcv volts
guitarbaby
Posted: 03:57pm 22 Mar 2009
can someone tell me when i have my meter at 20 dcv and it reads 2 or sometimes as high as 3 or 4 how much is this
CraziestOzzy
Posted: 06:43pm 22 Mar 2009
ummm, you have answered your own question
http://cr4.globalspec.com/member?u=25757
http://www.instructables.com/member/OzzyRoo/
Gill
Posted: 09:04pm 22 Mar 2009
maximum possible reading on this setting = 20 vdc
actual measured reading on this setting = 2 or sometimes as high as 3 or 4 volts.
Variation such as you indicate is usually caused by poor electrical contact.
Cheers Gill _Cairns, FNQ
guitarbaby
Posted: 01:24am 23 Mar 2009
thanks this is hooked to a small windmill i built very small experment so when wind blows faster the higher the reading will 3 volts charge a 12 volt battry over time was going to try this at the lake i have a solar panel that puts out 1 amp 15 watts but thought with little wind mill would be that much better thanks again
Posted: 01:40am 24 Mar 2009
Bad news I'm afraid, you need at least 13.5Volts to start charging a 12V battery - any less is not going to do anything. Perhaps it might be a good idea to read up a little about battery charging .
