Local Time 12:03 05 Nov 2026 Privacy Policy
Forum Index : Windmills : 80c NEOS
DaViD
Posted: 03:50am 08 Apr 2009
Hi fellas, All I've been able to find in disc mags that are 2"x1/2" are only rated for 80c temp. if I can cool the genny enough will this temp. rating work?
If your not living on the edge your taking up to much space!
GWatPE
Posted: 11:34am 08 Apr 2009
This temp rating is normal for neo's above N40. My 2"x1/2" round disks are N38 and 120C rated.
Gordon.
become more energy aware
DaViD
Posted: 01:45pm 10 Apr 2009
Hi Gordon, I've looked around on the web here in the states and have not had any luck finding any disc's that are below N40 grade. Can you tell me where I might find them?
niall1
Posted: 11:00pm 10 Apr 2009
hi David
just a thought..but even here in ireland on a hot day ..(alas a beautiful but rare thing .. ) the temp on a car bonnet can easily hit 60/70 degrees c ....80 seems a bit close ...
Edited by niall1 2009-04-12
niall
GWatPE
Posted: 11:42pm 10 Apr 2009
Hi DaViD,
I purchased my mags in Aus, from a ferrite and mag importer called Neosid. A lower temp rating give the undesirable possibility of unequal flux loss. If SaCo were more powerful, these would be the go.
Gordon.
DaViD
Posted: 01:31pm 11 Apr 2009
I'm going to keep looking for some higher temp. mags. maybe i'll run across some soon
DaViD
Posted: 03:42pm 29 Apr 2009
Thanks Gordon!!! I cant believe it, they have a place that is less than 40 miles from me that has them in stock! Edited by DaViD 2009-05-01
