Local Time 11:16 05 Nov 2026 Privacy Policy
Forum Index : Windmills : staggered groups of windings
brucedownunder2
Posted: 11:18pm 12 Apr 2009
Hi,, I think it was some time back ,,, but did anyone have success with the idea of staggered groups of windings for different cut-in voltages and outputs.
If so , could you share the results with us ,please.
Bruce
Bushboy
Posted: 12:17am 13 Apr 2009
Hey Bruce
Yeah that was me. Full thread here http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=749&KW=staggered
It seams to work fine, cut in speed is about 40RPM, in light winds its making a 1 to 2 amps for most of the day. The tail did furl too early, at around 16 amps.
I'm using it now on the new extruded blades, so far its working good though only seen 5 amps to date, really missing out on all the wind lately, even the Southern Cross is struggling to pump any water. Very tempted to fire up the chain saw and cut down a few tree's, but I want to sell the place later this year so need it looking its best.
If you have a spare stator I would recommend you try it.
brucedownunder2
Posted: 02:05am 13 Apr 2009
Thanks Glenn,,
I'm re-wiring a 60 at present,,cold and wet ,,so good to do these things .
I will certainly follow your instructions and re-wire a 80 ,and maybe a 100 .
Have you found a good wind block yet,,,?
Bruce
Bushboy
KarlJ
Posted: 08:38am 09 Nov 2009
OK here's an interesting one.
If you were to re-wire 1/2 for star and half for delta
would you still need a separate set of rectifiers for the two halves....
The advantages of dual stator with only one stator.....
Karl
GWatPE
Posted: 12:54pm 09 Nov 2009
Yes. 2 sets of rectifiers are needed as the delta windings would effectively short the star windings, if connected together.
Gordon.
become more energy aware
KarlJ
Posted: 02:00am 10 Nov 2009
Sounds like a winner
-outside the box a little -I like it!
80 series 1x7c + 1x7c delta.
are the 680uf 450V back to back caps on each set
still going to work or have I now over capped?
Karl
GWatPE
Posted: 11:02am 10 Nov 2009
I would wire the mill, both windings in delta. Makes better use of the wire to give a lower alternator winding resistance. Cap voltage multipliers take care of the cutin rpm and the low end wind loading while maintaining high performance at the top end with the lowest coil resistance when the current is max.
Gordon.
KarlJ
Posted: 12:00pm 14 Nov 2009
I knew that was coming......
delta 1.7times the cutin, voltage doubler 1/2 the cutin, already ahead so delta is a wise decision.
What sort of cutin would you expect?
ie windspeed with 2.5m blades and single stator.
