Local Time 11:59 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Mast vibration
DaViD
Posted: 09:16pm 21 Apr 2009
Hi guys, would it stop my mast and my blades from making so much
vibration if I was to move the blades another foot away from the mast and
counter weight the tail for balance?
If your not living on the edge your taking up to much space!
Posted: 10:56pm 21 Apr 2009
Hi David
Do you mean tower wobble, where the tower wobbles as the turbine spins around. If so, thats caused by a out of ballance turbine, and moving the turbine further out could make it worse.
Tower vibration is just a noise thats really loud if you put your ear against the tower. This is fine unless your tower is mounted to the roof, a bad idea.
DaViD
Posted: 12:30am 22 Apr 2009
Hi Glenn, It's a vibration that comes down through the mast then to the metal (yes roof) of my shop. So I guess i'll get a taller pole and mount it?
KiwiJohn
Posted: 08:59pm 25 Apr 2009
David, if your machine is in balance and the vibration is just an annoying noise being transmitted into the building maybe you can cure the problem by isolation.
For example, and these are just ideas off the top of my head, put the foot of the mast loose fitting into a tall socket supposing you have a 3" mast you could use a couple of feet of 6" pipe as the foot and fill the space with well tamped sand, stand the mast on a rubber isolation foot a big engine or machine mount etc.
If you have a really strong roof and dont like the idea of isolation maybe you can damp the vibrations by mass, mounting the mast on a slab of concrete perhaps.
Just a couple of ideas which might all be worthless!
DaViD
Posted: 03:12pm 29 Apr 2009
Hi KikiJohn, The only problem with isolation is my roof is not all that strong. I was just trying to cheat and gain some extra air without the added length of mast.
It seems to pulse when the blades past the mast and the pulses increase to become a vibration when the rotor speeds up. I guess when I get the time I'll put it in the ground.
robbo
Posted: 10:26pm 01 May 2009
Hi there David,
I had the same problem with my mast, it was vibrating due to the blades running past the pole. Mine was about 6 inches from the pole I think.
I isolated the vibration from the house, by adding some thick rubber between the pole and the support that lead to my house. It worked really well.
I used an old thong for the filling. About 2cm think.Edited by robbo 2009-05-04
"the Earth was not given to us, by our fathers, rather, it is lent to us by our children".
DaViD
Posted: 12:59pm 02 May 2009
Hi robbo, I wish it was that simple for me. My mast is attached to the ridge on my roof with guy wires at each corner. I'm just to lazy to take it down and mount it on a higher mast
MacGyver
Posted: 05:44am 12 May 2009
Hi, new to this forum. Over the years, I've encountered many "vibration"
problems and found that it's not always a question of balance, although
balance is critical especially with larger-diameter up-wind blades.
One thing that often gets overlooked is the fact that as each blade passes
in front of the tower, the airflow spilling off the airfoil is spoiled a little
bit by the fact that the tower is in the way. This will often times set up a
kind-of "harmonic" beat and it'll drive you crazy.
Down-wind blades suffer a similar problem as each blade passes through
the tower's shadow. An easy solution is to either extend the blades away
from the tower or elevate them using a single-post tower extension
(which still interferes, but not as much).
Hope that helps
Copeville, Texas
