Local Time 11:56 05 Nov 2026 Privacy Policy
Forum Index : Windmills : My plans for a new wind turbine.
DeanC993
Posted: 02:12am 12 May 2009
Hi every one im new to the fourm i am about to make a new wind turbine this is my present one http://www.youtube.com/watch?v=k8aciL1dD10 plz look at part two after you see part one, im making a wind turbine with a stepper motor and got to make some pvc pipe blades i have to make a hub does anyboady no how to connect the blades to the hub
Dean Cheevers
Posted: 03:16am 12 May 2009
Hi Dean
Have a look at my Mini-mill project. It uses a stepper motor and PVC blade, it might give you some idea's.
http://www.thebackshed.com/windmill/assemblyMini1.asp
( To add a link, use the little Add Hyperlink button, forth from the left after B I and U )
DeanC993
Posted: 02:48pm 17 May 2009
[hey can you get the wheel of by a alan key get it off?
Dean Cheevers
