Forum Index : Windmills : Accidental Post - Originally in Wrong Forum.
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1138 |
░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ ░░ WORK IN PROGRESS F407xGT6 Update ░░ Please don't reply to thread ░░░░ ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ TODO ----- --- Changes from Picomite 6.00.02RC5 --- https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17777#235710 Functions MM.HRES, MM.VRES, MM.VER, M.I2C, MM.FONTHEIGHT, MM.FONTWIDTH, MM.PS2, MM.HPOS, MM.VPOS, MM.ONEWIRE, MM.Errno, MM.ErrMsg$, MM.WATCHDOG, MM.DEVICE$ are now all implemented as written and none of them are converted to MM.INFO calls by the pre-processor function TEMPR(Pinno [,timeout]) 'new optional parameter timeout to override the default (200mSec) to allow for slow devices command TEMPR START GPno [,resolution(0-3)] [,timeout] 'new optional parameter timeout to override the default (100, 200, 400, or 800mSec) to allow for slow devices Have a look on github at fun_tilde in functions.c, llist in commands.c, changes to str_replace (fixes a bug where replacements could happen incorrectly) and tokenise in MMBasic.c. I'm going to add MM.CMDLINE$ and the MQTT MM.s as well in the next RC which will get rid of the various background variable creation code that current supports them. Automatic length adjustment for string constants. Where a constant string is less that 16 characters no heap will be used. The data is stored within the pre allocated table for the variable definitions. String variables defined with a LENGTH of less than 16 (was previously < 8) are also stored within the variable definition and require no heap allocation. Added @( function. i.e. PRINT @(x,y) when outputting to the console. OPTION CHARS will enable x,y to be entered as row,column in lieu of pixels. OPTION CHARS OFF will return to pixels. Fix MATH V_PRINT GetSystemMemory performance stuff -------------------------------------------------------------------------------- ARMmiteF407xGT 5.07.02 -for STM32F407VGT6,STM32F407ZGT6,STM32F405RGT6 In Progress Armmite F407xGT6 5.07.02 Beta 1 BYVAL and BYREF qualifiers added to SUB definition. PWM will set output pin to OC(Open Collector/Drain) if frequency given as -ve number. PWM fixed issue where a frequency change was not recorded, so returning to the original frequency did not result in an update. LIBRARY SAVE future proofed for 0xFF token 16bit tokens. OPTION LCDPANEL accepts [,INVERT] to invert colours on ILI9341 and ILI9488 Support for LCD Display ST7796S 480*320 SPI Fixed issue where MEMORY command erased saved variables. LINE command enhanced. LW given as -LW will set LW in all directions Armmite F407xGT6 5.07.02 Beta 0 This first Beta includes all enhancements/fixes as per Armmite F407 5.07.02 Beta 3/4. see here These include: CAN [OPEN|CLOSE|START|STOP|FILTER|SEND|READ] commands added FSMC pins now available for MMBasic use if no parallel display configured. These additions/differences apply to the F407xGT6 5.07.02 The additional flash allows increased size for the firmware.The firmware is now optimised for speed rather than size. No LCD Panel is configured by default. The LIBRARY is now an additional 128K flash section separate to program memory and does not rely on the SPI Windbond flash chip. OPTIONS are moved back into flash so not dependent on RTC battery. SAVED VARS are moved back into flash so not dependent on RTC battery. Both are reset to default when new firmware is loaded. The Command Line Buffer is moved to RTC Ram (first 1K) OPTION RESET will clear the options and also the Command Line Buffer. RTC Ram is also cleared with an MMBasic RESET. LIBRARY RESTORE will restore any existing library after OPTION RESET. MM.INFO(DEVICETYPE) added. Returns "Feather" for Adfruit feather else "" I2C SLAVE mode added. OPTION Fn5-9 added. LINE AA command added LINE GRAPH command added LINE PLOT command added MATH CROSSING() added MATH CRC12 added MATH POWER added MATH SHIFT added MATH(CHI ..) function added MEMORY PACK/UNPACK added MEMORY INPUT/PRINT added SORT command enhanced as per Picomites. Armmite F407xGT6 5.07.02 Beta Releases This firmware supports STM32F407xGT6 chips with 1 Meg Flash.i.e STM32F407VGT6 100 pin, STM32F407ZGT6 144 pin, WeAct STM32F405RGT 64 pin and Adafruit Feather STM32F405RGT 64 pin . The links below point to the latest Manual, Firmware, Source and a FotS page dedicated to the ARMmiteF407xGT version. See the FotS page for details on the boards that have been tried/tested. Latest Manual Armmite F407xGT6 User Manual Latest Firmware There are three versions of the firmware: The default version uses the default PE3 and PE4 pins for MMBasic Reset and Switch to Serial Console on the 100 and 144 pin boards. The PC13Reset versions uses PC13 to test for MMBasic Reset and Switch to Serial Console. The Adafruit version is for the 64 pin Adafruit version with a 12MHz clock. Armmite F407VGT6 Firmware (default) on GitHub Armmite F407VGT6 Firmware (PC13Reset) on GitHub Armmite F407VGT6 Firmware (AdaFruit Feather) on GitHub CFunctions Header File CFunctions Header File (ARMF4CFunctions.h) Source Code Source Code on GitHub Fruit of the Shed FotS Armmite F407xGT6 Footnotes in this first post will be used to reference further updates as required. --------------------------------------------------------------------- Edited 2026-07-25 12:35 by disco4now F4 H7FotSF4xGT |
