Local Time 01:17 10 Aug 2026 Privacy Policy
Forum Index : Windmills : 30 volts
DeanC993
Posted: 06:13pm 08 Jul 2009
hi guys TODAY I READ 30 VOLTS!!! OF MY STEPPER MOTOR WIND TURBINE 50 MILLAMPS:( BUT 30 VOLTS:) I HAD IT RUN THROUGH A 10 DIODE BRIDGE RECTIFIER INTO A 50 VOLT CAPACITOR AND DIRECTLY TO AN LED WITH A RESISTOR CAN SOMEONE TELL ME IS THAT GOOD ENOUGH To CHARGE A 12 VOLT BATTERY OR DOES THE AMPS HAVE TO BE HIGHER? i know it would be good for at least 4 double a's very happy today(:
Dean Cheevers
Posted: 11:46pm 08 Jul 2009
Hi Dean
Yes 30 volts is good, thats more than the charging voltage for a 12 or 24volt battery. 50mA isn't a lot though, and its the amps that will be doing the work.
How big is your stepper motor, approx size?
readyakira
Posted: 01:42am 18 Jul 2009
If you are charging a car battery 50ma will be more damaging then good over time. It will allow the crystals that grow in the battery to be come bigger thus preventing the battery from accepting a full charge. 50ma could be used to float charge (keep a full battery full) maybe, but regular charging no so much. Even remote control car batteries charge with more ampereage. um, maybe a few nicad 1.5 in series, but then there a are even charge issues to deal with.
Don't you think Free/Renewable energy should be mandatory in new buildings?
DeanC993
Posted: 02:16am 18 Jul 2009
Thx readyakira advice taking i am now charging 4 double a's as quick a 1 thanks by
Dean Cheevers
