Local Time 11:34 05 Nov 2026 Privacy Policy
Forum Index : Windmills : what diode?
daggit
Posted: 01:30am 14 Aug 2009
getting closer to completing my windmill. what kind of diode do i use to connect my dc motor to my battery bank?
Like this one?
shooting at the dark
Posted: 03:18am 14 Aug 2009
Hi Daggit
What sort of power/amps are you expecting?
davef
Posted: 10:44am 14 Aug 2009
I do not understand what you are trying to do? If the DC motor is rated to work at the battery voltage you just connect it directly.
daggit
Posted: 11:31am 14 Aug 2009
I don't know what kind of power I'll get for sure. I know it wont be over 40 amps from my treadmill motor (hoping maybe 6-10 amps) but I might add another smaller windmill. I KNOW it wont make 100 volts.
If you hook it up to the battery directly the voltage could flow backwards to the spinning the dc motor right?
Posted: 11:47am 14 Aug 2009
A treadmill motor would only supply a few amps, maybe 10 amps at the most, so you can use a cheap diode. Diodes can be conneced in parallel, to increase the total current handling capacity.
A 1N5404 is rated at 3 amps, 400 volts, and worth about 25 cents. 4 connected in parallel will give 12 amps at 400 volts. For the price, grap a couple extra and add them to the circuit, just to be safe.
Posted: 11:50am 14 Aug 2009
Hi Daggit
Davef's right, without the diode, the motor, used as a generator, will act like a motor. When there isnt enough wind to charge the battery, the battery will drain into the motor and spin the blades.
daggit
Posted: 12:12pm 14 Aug 2009
hmm, i think i already have some of those
daggit
Posted: 12:15pm 14 Aug 2009
by the way the one I have a link posted to would work right? Those little bitty ones seem so small to put in the power line. Is there I nice looking way to wire those?
