Local Time 02:13 10 Aug 2026 Privacy Policy
Forum Index : Windmills : Smart Drive Efficiency Results
Smart Drives
Posted: 09:09am 30 Aug 2009
The following data is + or - 5% , but gives a general idea of each motor at various voltages. If the result is
N/A startup is over 500rpm (not worth doing).
These results are pure rewinding no added bits such as capacitors. BUT all results have had the stator manually decogged !
100S 12v star: 40%
100s 12v delta: 55%
100s 24v star: 60%
100s 24v delta: 70%
100s 48v star: 75%
100s 48v delta: 85%
100sp 12v star: 75%
100sp 12v delta: N/A
100sp 24v star: N/A
100sp 24v delta: N/A
80s 12v star: 45% decreasing to 25%
80s 12v delta: 25%
80s 24v star: 40%
80s 24v delta: 40%
80s 48v star: 58%
80s 48v delta: 60%
80sp 12v star: 63%
80sp 12v delta: 75%
80sp 24v star: 85%
80sp 24v delta: 90% but 480rpm startup
80sp 48v star: N/A
80sp 48v Delta: N/A
80p 12v star: 78%
80p 12v delta: N/A
80p for 24v & 48v N/A
60s 12v star: 15%
60s 12v delta: 25%
60s 24v star: 28%
60s 24v Delta: 40%
60s 48v star: 43%
60s 48v delta: 55%
60sp 12v star: 55%
60sp 12v delta: 60%
60sp 24v star: 75%
60sp 24v delta: 85%
60sp 48v star & delta N/A
60p 12v star: 65%
60p 12v delta: 75%
60p 24v star: 85%
60p 24v delta: 90%
60p 48v star & delta N/A
GENERAL RULE: anything under 50% has low power.
Good combos for charging batteries with a lawn mower
engine are as follows . lawn mower rpms are approx 3500rpm with 2:1 gear bring rpm back to 1750rpm.
then use 80sp 24v delta 1kw. 100p 48v delta 1kw.
60p 48v star 750watt(3:1).
Cameron.
All smart drive parts sold
Custom built turbine parts on
Multicam flatbed CNC Router
Posted: 12:50pm 30 Aug 2009
Wow Cameron, good work.
It must have taken ages to do all this testing. How did you test the different combinations.
Smart Drives
Posted: 07:41am 31 Aug 2009
Sorry i cant take the credit they are results from
eco-innovation.
Cameron.
carl1
Posted: 10:23am 31 Aug 2009
here are a few test results regarding F&P efficiency:
torque input x rpm versus dc charging.
so the loss includes bearing friction and rectifier loss:
tested on a lathe setup:
F&P 60DS 1S-12P delta 12 volt:
@ 346rpm , charging 6.5amps 68% efficiency
@ 950rpm charging 35amps 64% efficiency
F&P 80SP delta 12 volt
@ 346rpm charging 10 amps 71% efficiency
@ 950rpm charging 32 amps 65% efficiency
Harald
