Local Time 11:30 05 Nov 2026 Privacy Policy
Forum Index : Windmills : GE 5SME22NJ028
davef
Posted: 09:13am 02 Sep 2009
Does anyone know if this unit has another more popular name, as there are no hits on Google. I have had suggestions it was either used in the original F&P "Gentle Annie" or maybe a Simpson washer.
It has three large magnets on the armature and 10 wires plus a ground wire. Strong cogging and 24 wire slots.
I'll take a picture if no immediate replies.
Thank you,
davef
brucedownunder2
Posted: 08:34pm 02 Sep 2009
Yes, I have a couple of them ,,one I took apart .
I also think they came out of the F&P dryers ,as they have a ribbed drive belt.
I set mine up years ago ,but can't remember the results. Must have been dismal as I canned the project. Think I tried all sorts of wiring . Lots of cogging .
Bruce
Bushboy
davef
Posted: 07:30am 03 Sep 2009
Yes, the ribbed drive pulley does suggest something other than a washing machine.
Seems odd to use an electronically commutated motor in a dryer, but then again the dryer we have is about 25 years old and only has one speed . . . slow!
Not worried about cogging as this unit could be for a microhydro system to complement a wind plant.
Looks like I will have to connect it to a lathe and do some Volts/Current/Power/Load runs on it.
Thanks,
Dave
herbnz
Posted: 08:34pm 03 Sep 2009
Hi dave
I have used these for hydro units They are out gentle annies two three phase windings one low voltage brown , brown/black. purple others are three sepatate windings.
need higher revs ie 1200rpm to charge 24v limit about 6A but overheat before this. can re wind i have one here making 30A but running 3000rpm . Mostly nowdays I use smart drives but if eff comes in these are the answer I have one on each of my pipelines to take over when in a drought ie even at 3000rpm no load loses 10 Watts smart drives 1200 rpm lose least 60 in bearings alone.readily available in junk yards windings normally alloy .
Can say lot more but no time now
Herb
davef
Posted: 07:50am 04 Sep 2009
Herb,
Thanks for the added info. 24V at 6Amps, if at 50% efficiency, is roughly what I expect to get. Efficiency is what I am after as 150W is probably a bit light for a F&P.
When you have the time I would appreciate your comments on rewinding, etc.
Cheers,
Dave
herbnz
Posted: 07:55pm 08 Sep 2009
Hi Dave
Better transfer this to other stuff.
These are 8 pole machines .
not easy to dismantle but the disc grinder solves that.
Give me your head , flow, pipe line ,battery voltage ,expected wheel dia or can we change this ?
etc and I will sort out details I do a fair bit of work in hydro design as well as my own .
Herb
davef
Posted: 08:07am 09 Sep 2009
Moved to <Other Stuff>
