Local Time 11:26 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Commercial 400-Watt Windcharger
MacGyver
Posted: 01:36am 07 Sep 2009
A friend was going to buy this for his RV and asked my opinion:
http://ww
w.boatersworld.com/product/199870320.htm
All my windmills pump air, so I'm basically clueless as to what to tell him.
The little windcharger weighs 17 pounds and is cast aluminum, puts out
14.8 volts (400 watts @ 27 amps -- ideally) and costs $600.00
I'm a little concerned with the tail being in the shadow of the tower, but
maybe that is a moot point. Also, it looks like there is no furling or over-
speed device. The blades are carbon fiber, so they will likely not part
even in an over-speed situation.
Can anybody advise me or should I just put it on my to-do list and build
one for my friend?
Dinges!:
Thank you for your help. I still can't post a picture to save my soul. It
just posts "code"!Edited by MacGyver 2009-09-08
Copeville, Texas
GWatPE
Posted: 08:45am 07 Sep 2009
  MacGyver said  The blades are carbon fiber, so they will likely not part even in an over-speed situation.
Blades that are black are not neccessarily carbon fibre. These Blades, on an Air-X windmill that you post a link to are black and are GRP, and not CF. These windmills are rated at 400W at very high windspeeds. On land, I haven't seen them produce rated power. In high winds the blades get noisy.
Better with the big brother, Whisper200.
Gordon.
become more energy aware
oztules
Posted: 09:26am 07 Sep 2009
I have heard nothing good about them. There are two on the island I know of.
The one in town has it's blades tied down... and they have been for the last 4 years (neighbours threatened to do some thing antisocial to the owner if he didn't shut it up....
The other on a fishing trawler. That one had the blades shot off it.... apparently from someone on shore because of the banshee noise it made when it came into port and was anchored there for while..... Not sure of the voracity of this last one, but I did see it when I was fixing the voltage control computer on the 50 kva generator on board.... and they looked shredded from something nasty.
Word around the village was that however it happened, it may have saved the skipper from being keelhauled at a later date....urban legend???
It was never replaced.
..........oztules
edit ..... maybe I mean Island scuttlebutt Edited by oztules 2009-09-08
Bryan1
Posted: 09:41am 07 Sep 2009
hehehehehe Oz,
Thats probably the reason why the air-X on the small 5 acre lot behind us never turns even in a gale. In the 5 years I've lived here i've never seen it turn and I did ask the new owner what was wrong with it. His reply was he tried to get it going but the previous owner had poured a full tub of loctite in it not long after he bought it. I asked him if he would like another wind genny and his reply was the noise of his generator would be quieter than any wind genny as he never heard a quiet one. He has yet to take up my invitation to come and listen to my 2hp conversion.
Cheers Bryan
oztules
Posted: 10:22am 07 Sep 2009
Yes Bryan,
apparently the air-x is socially acceptable either rope tied, loctited, or battered to death with a blunt instrument.... and in a 5-15mph wind, the output is about the same as the unfettered ones anyway.....
.........oztules
MacGyver
Posted: 05:25pm 07 Sep 2009
Well . . . I guess that answers that, eh?
As far as the blades being made of carbon fiber, the ad on Cabella's Web
page (one that I absolutely could not make work as a link!) actually stated
they were constructed of CF.
Thanks for the replies; guess it'll be just another entry on my "to-do" list.
I'll have to cook one up for my friend one of these days.
While I'm on that topic, I intended to manufacture a permanent-magnet
alternator, copying the design of an automotive type, replacing the field
coil with a ceramic ring PM. Anyone here done this before?
M
Copeville, Texas
oztules
Posted: 08:33pm 07 Sep 2009
I haven't done it... mostly because I listened to those that did try to adapt car alternators to wind duty.
Technically, it works. In practical terms, it is less then ideal. An average performer for the work.
If you do wish to test this, make sure you use a non-magnetic shaft (bronze or S/Steel).... or it will short the flux from the magnet.. and very little will be left to go between the claws.
When it was an electro magnet, the shaft can help to channel the flux out of the core to the claws at each end... with permanent magnets installed instead, the shaft simply shorts the flux from the N to the S pole.... without it having to go through the claws and jump the gaps between the fingers.
Ed from Windstuff now has also done a lot with these things, and you may gleam some ideas from his foibles. It is interesting to note, that whilst he had some success with these things, he uses axial flux units now... they are immeasurably better for wind use.
Here is his site: windstuff
Notice that with strong Neo's with good placement and magnetic paths, for a standard winding you need 600 rpm just to get cutin. For ceramics and claws, it will be even sadder.
He has plenty of other projects to wade through too.
...........oztulesEdited by oztules 2009-09-09
MacGyver
Posted: 01:07am 08 Sep 2009
I was going to use solid round aluminum press-fit into the center of the
ring magnet (which is 7" o.d.) and build a tang (tab) on each soft-iron
face, which would each key into a slot in the aluminum to hold its place
relevant to the opposing plate. The shaft of this thing would be no larger
than 5/16" drill rod. I was going to build the thing up, then center it in a
4-jaw and cut the axle hole last. I really DON'T need to get it all done
and have it wobble!
Along a similar line of thought: I took apart a bicycle generator back in
the day and manufactured a similar device (only way larger), which was
very hard to turn and subsequently put out lots of amps. I may go that
way with this before I'm finished with it.
I was aware of the flux-robbing from another project years back, but
thanks for the heads up. I'll check out Windstuff before I start this
project.
Wait a minute; another new project?! What am I thinking?
Copeville, Texas
JimBo911
Posted: 05:16am 13 Sep 2009
I have had an Air X flying at my place for about six years now. In all that time I have had very little problems with it just had to readjust the voltage regular once. It does take a good blow to get things going. As far a producing wattage well that's a different story. As soon as it reaches max out put it goes in to over speed and sits there for while making no power. If a storm rolls in and hits the mill hard it goes in to over speed as it does this it makes a sound that sounds like an F16 fighter jet just made a high speed pass over the house that will make people duck for cover (no joke) I put it up cause I just had to have something up there spinning. It is a tough little mill has survived many a storm but not much on production. It does make a lot of swishing noise on a regular basis.
