Local Time 05:27 10 Aug 2026 Privacy Policy
Forum Index : Windmills : Advice needed
oilydave
Posted: 01:18pm 06 Oct 2009
I am building a windmill and currently have a 600 watt, 120 Volt DC Motor, 1/2 HP.
My ultimate goal is to use a battery to invert power to run my Pellet Stove when the power goes out. The Pellet Stove has a max. wattage of 440 W (Start cycle + test).
The start cycle for the pellet stove is 340 watts and the normal run wattage is 255 Watts.
I need advice on what i need to for a charge controller and dump load configurement.
Ultimately I would like to use this as my power source for the stove and recharge it off my wind mill.
http://www.canadiantire.ca/AST/browse/4/Auto/SolarPortablePo wer/PowerPacks/PRD~0111810P/Motomaster%2BEliminator%2B600A%2 BPowerBox/CROSSSELL~0111591%20Motomaster%2BEliminator%2B700A %2BBooster%2BPack.jsp
Will this work and if not what would you recommend?
Dave
Downwind
Posted: 01:41pm 06 Oct 2009
Hi Dave,
Whats the http. link for? As it would not work for me.
Think it is broken??
Pete.
Sometimes it just works
9c12m
Posted: 01:55pm 06 Oct 2009
Try http://tinyurl.com/yegocrz
Downwind
Posted: 02:24pm 06 Oct 2009
Hi Dave
I thought it was a link to your pellet stove.
The inverter on the link has a lot of bells and whisles that i see as glossy junk if you dont need them.
I think if you want an inverter buy an inverter, if you want a compressor buy a compressor, not a compressor that thinks its an inverter.
But thats just me and my thoughts.
20 amp/hour battery is rather small for a backup supply and would be hardly worth builging a generator to charge something that small.
400 watts is a small inverter in my mind, as what one starts off with the intension of running often gets bigger if you have the choice.
Then again the bigger the inverter the bigger the battery capacity and so no. Where do you stop??
These are just my thoughts and i am sure other members will give different views.
Welcome to the 4M.
Pete.
oilydave
Posted: 02:25pm 06 Oct 2009
Hi Pete,
the website is: www.canadiantire.ca
The product is the Motomaster Eliminator Power Box 800.
Some info. I could cut and paste:
Completely redesigned to deliver greater power for longer periods of time and to increase durability and rugged appeal
Three household outlets to power up to 600W of appliances and electronics simultaneously
Long-lasting endurance: 28 Ah power cell
Integrated AM/FM radio and alarm clock to keep you informed during emergencies or entertained during recreational activities
Also features boosting capabilities, digital power display, safety light and plug-in-and-forget charging
Includes booster cables, AC charger and 12V socket cable
oilydave
Posted: 02:29pm 06 Oct 2009
Hi Pete;
Thanks for the help so far. I do not need the the Motomaster Power Box 800 with the additional bells and whistles, it was just a convenenient source of transportable power.
What size inverter would you recommend?
Downwind
Posted: 02:49pm 06 Oct 2009
Inverter size and type is a personal thing that best suits your needs.
I dont like driving things to their max. upper limits.
To me a 1000w inverter would be a starting point but then that increases price range etc. and might be more than you require.
I would rather something that i could use off any 12v battery rather than rely on an internal built in battery that might fail when needed most.
If you want a selfcontained unit have you considered a computer ups supply.
It might be cheaper.
I used one for some time as a portable supply and added a plug that i could plug a external battery into.
It was ok but still a toy from my point of view, but i had it sitting there doing nothing so put it to use.
Pete.
