Local Time 11:19 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Mini mill
Dunks
Posted: 10:49am 25 Oct 2009
Hi Guys,
Beibg a novis at this electrical stuff.. I'm wondering if one (or2 or 3) of these mini mills from a printer etc. could be used to help trickle charge my 12v battery on my boat which I use to run a bilge pump. I currently have a dash board type solar trickle charger which puts out about 30 mili amps, I don't really want to put a bigger solar on as I have had a couple of thefts already. Any idea how many mili amps one of these baby's might put out??
I'm open to any help on how to wire it up if anyone is willing.
Thanks very much,
Dunks
Dunks
Posted: 11:30am 25 Oct 2009
Hi Dunks
It all depends on what motor you use. If you can find a big stepper motor or 3 phase ac permanent magnet motor from a photo copier or big printer, then you could easily get half an half an amp or so into 12 volts. Do you have any friends in the IT or photocopier/office equipment business?
Dunks
Posted: 11:34am 25 Oct 2009
Hi Glenn,
Thanks for the advice
Pardon my ignorance, but what is a stepper motor?
Thnks
Dunks
Dunks
