Local Time 11:20 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Shouldn’t it be making more?
terrapinlogo
Posted: 04:00am 26 Oct 2009
i have built a windmill out of a smart drive motor and have it up in the air and it is only producing 5v in 15km/h winds. shouldn't it be making more?
i have re wired it as described here: http://www.watchtv.net/~rburmeister/smart%20wiring.html
anyone have any ideas?
Damian
If it doesn't work hit it with a bigger hammer.
If it still doesn't work you probably shouldn't of hit it.
Dingdoc
Posted: 05:03am 26 Oct 2009
Where are you measuring the 5V?
Is it ac from the fields, dc out of the rectifier?
What do you have it connected to?
Some more detail might help.
Trev
terrapinlogo
Posted: 05:08am 26 Oct 2009
i get 5v from between any two phases and from a rectifier when i connect two phases to it. at the moment i don't have it connected to anything (yea i know it could spin out and bust its self up but its been up like that for three months and hasn't done it yet)
Dingdoc
Posted: 02:35am 28 Oct 2009
Sorry I can't be of much more help at the moment Damian.
My wind gen is only half finished and I keep getting side-tracked with other projects.
It looks as if your alternator rewire is OK but you are just concerned about the low end output.
Have you measured the voltages at higher wind speeds?
Hopefully someone with a similar setup can give you some info on their output at low speeds - I had a quick look for output graphs but couldn't find much.
Trev
KarlJ
Posted: 10:29am 28 Oct 2009
only take one stuffed up wire (in the re-wire) to ruin your day.
is it a 60, 80, 100 series?
what size prop? how big is the tower?
what sort of site is it on?
Might want to connect all three phases to the rectifier!
Karl
Dingdoc
Posted: 03:36am 30 Oct 2009
Damian
I did a 'quick and dirty' check of the no load output voltage of my rewired F&P handcranked gen and found it was producing around 5Vac at 60 rpm (across 1 ph).
If your prop speed is around this rpm at 15kph (4m/s) it would indicate that your alternator wiring is probably OK.
Perhaps you could experiment with a voltage doubler circuit to see if you can get a useable output at low wind speeds.
Trev
terrapinlogo
Posted: 03:48am 30 Oct 2009
KarlJ: off the top of my head i think its an 80
Trev: Voltage doubler circuit link or schematic please and yea at a guess it was probably about 60rpm
Posted: 04:00am 30 Oct 2009
Hi Damian
Can you try shorting out any two of the 3 wires on your windmill next time its running. If its wired up ok, you should get a little spark and the windmill will shudder and grind to a halt.
terrapinlogo
Posted: 04:02am 30 Oct 2009
yep it defiantly grinds to a halt i don't rember seeing a spark though was probably there i just didn't see it
Dingdoc
Posted: 05:36am 30 Oct 2009
Damian
Try this-
http://www.thebackshed.com/windmill/articles/GordonsCapMod.a sp
Trev
