Local Time 11:16 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Hugh Piggot turbine
KarlJ
Posted: 10:47am 04 Nov 2009
Anyone interested, I found this on ebay today
http://cgi.ebay.com.au/WIND-GENERATOR-PIGGOTS-12V-AND-24V-DI SCS-UP-TO-20A_W0QQitemZ290365235089QQcmdZViewItemQQptZAU_Gad gets?hash=item439b1ddf91
Would it be any good?
niall1
Posted: 11:20pm 05 Nov 2009
hi Karlj
this reply is a bit late but its very hard to tell the condition of the alt by just a pic like that....
it could be fine but without seeing it disassembled its impossible to tell
depending on materials used axials can need periodic maintenance checks for stator alignment (rubbing problems) and possible magnet corrosion (environment)..bearing wear etc
a close up pic of the magnet rotors would have been better...were they nickle or epoxy coated ? was polyester or epoxy used to pot them ? and so on ....
i,ve seen one or two that cut corners on basic things which shortened their life a lot....i,ll include myself in that category ... Edited by niall1 2009-11-07
niall
