Local Time 11:16 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Storm Damage
brucedownunder2
Posted: 08:20pm 05 Nov 2009
Well, the local storm season is here.
Last night my blades,tail were wiped out ..
Been looking around for an hour now ,,no sign of the blades (2 of them) . These were the abs plastic carved blades ,very strong ,but also light, so they could be acres away.
The road and surrounding paddocks look like a war zone , and to make things worse,one of my downpipes to the water tank was twisted away from th einlet,bugger.
Anyhow,, I'll pull everything apart thats left and start again..
Bruce
Bushboy
fillm
Posted: 10:28pm 05 Nov 2009
Hi Bruce ,
Sorrie to here about your mill damage , it is a inherant problem with the F&P that I have seen on many an occassion with my dual, where the stator becomes saturated and the mill is then out of controll .
This is main reason I decided to go with the Ax Fx , as there is not a chance in the world it can start if the stator is shorted and will stop if needed in the most severe conditions .
