Local Time 11:16 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Technical and electeonic information
marcwolf
Posted: 01:44am 12 Nov 2009
Hi Folks
Well - my solar panel system has now been installed and it is sitting up there generating 870W as we speak (type?)
As I have had to put my wind generator on the back burner until this was installed I am now starting it up again.
Now the solar panels puts out about 170V depending on lighting conditions so they are wired in series. The Invertor needs a minimum of 100V to start and can handle upto 500V.
As the invertor is a 2000W and my panels are rated max 1000W I have some extra conversion capacity.
So here are some very technical questions re power and current that need some help with.
I have 2 isolated circuits both producing DC. Each circuit is isolated from the other with a set of heavy duty diodes.
Circuit 1 makes 170V DV approx at 5A
Circuit 2 makes 120V DV approx at 4A
If I join the two circuits together what voltage will I be getting and what amps. Remember that the two circuits cannot back-feed each other.
Also - for a tower - round tubing or box tubing?. I can get various quality of 4" diameter tubing and I was wonder what might be the best.
Many thanks for any advice
Dave Edited by marcwolf 2009-11-13
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
fillm
Posted: 02:30am 12 Nov 2009
Hi Dave ,
Good to here your solar is up and running , as far as the converting up to that voltage and combining it with the solar I am sure there are some here that can advise on that .
I would be going with the round for a tower .
marcwolf
Posted: 02:37am 12 Nov 2009
Hi Phil
I am planning to give you a call soon re getting some parts to make the rest of the windmill.
Anyway - I have 2 choices re generating the power. I can run the F&P almost in native mode and use voltage doublers to get the 100V+
Or alternately I have a 12V to 110V 1KW invertor here that I can modify to give 100V+ DC out and make the F&P generate 12V to feed it.
Oh decisions.. decisions :> I am not that worried about a little loss, jusr a way to suppliment the solar when the sun don't shine.
Take Care
Dave
RAW CODE!!!!!
RossW
Posted: 06:20am 12 Nov 2009
Unless there's something else going on you haven't described, you will find that circuit 1 will be providing 5A at 170V and circuit 2 will be providing NOTHING.
If circuit 1 is the PV array, as the sun goes down and its voltage drops - once it gets to 120V, you will get current from both circuits.
Once circuit 1 drops below the voltage of circuit 2, your combined output will be 120V at 4A.
There will be a *LITTLE* wiggle room there as the resistance of cabling, characteristics of the diodes etc, will let the two circuits share better when their voltages are VERY CLOSE TOGETHER, but simply diode-ORing them as you described won't give you what I think you wanted (eg, they won't give you 9A!)
GWatPE
Posted: 08:39am 12 Nov 2009
Hi Dave,
it would be better if you gave a bit more info. For instance, if the loading could pull down to 120V, then you would get the 9A at 120V. I spen a lot of time on my own parallel supplies feeding an inverter, and it is all about matching.
Gordon.
become more energy aware
marcwolf
Posted: 10:19am 12 Nov 2009
Hi all.
Thanks for replying. I will try and give more information.
Ok - Circuit 1 is the Solar panels. They of course fluctuate depending on the sun conditions down to where they produce nothing when it is dark.
Circuit 2 will be the F&P. I have been given a 12VDC to 110VAC 1KW invertor. I am planning to use the F&P plus some buffer batteries to feed this invertor. I will then take the output and rectify it with a full bridge to make 110DC (I will also be having capacitors etc for filtering)
I would like to combine the power from both circuits into the main invertor. As both circuit will not be 'stable' as in I can relay on Circuit 2 being on or off. Circuit 1 will be changing a lot depending on sunlight etc.
I could get another invertor for circuit 2 but the difficulty in hooking it into the 240VAC will make costing impratical. I prefer not to have to buy another $2000+ Grid invertos and the cheaper invertors will have trouble matching the 50HZ frequencies.
Hopes this give enough information
Dave
p.s. My Grid invertors is a CMS2000. I have 6 solar cells. At 10am this morning I was gettin 174VDC 5A.
RAW CODE!!!!!
