Local Time 10:54 05 Nov 2026 Privacy Policy
Forum Index : Windmills : cog free coil/ magnet ratios?
Posted: 01:19pm 07 Jan 2010
The Shibura alternator I got here does not cog at all, much less than the F&P converted to 7 phase which I also have to experiment with.
I am wondering if there are other coil/ magnet ratios that produce no cogging?
For those who are unfamiliar, the Shibaru has an outside 12 coil stator on laminated iron pole shoes. They are connected in 3 phase star (4 coils in series).
The rotor within has also a laminated construction with 10 pole shoes. A PM of unknown shape within magnetizes these in a N/S/N/S... alternating configuration.
I ask this question as it occurred to me that one could use a similar ratio on AXFX alternators with the inclusion of iron filings encapsulated in epoxy, within the coil centers.
Is this a crazy idea or would it provide some improvement to the magnetic path?
For a reasonable number of turns in the coil one needs very powerful magnets (expensive and dangerous), would the iron filing idea permit a smaller magnet for an identical coil gap?
I'm looking forward to read your comments.
oztules
Posted: 10:08pm 07 Jan 2010
Not crazy.
Jerry of fieldlines used a 14:11 ratio for an axial flux with iron cores.
It was designed for mechanical /cogging cancellation, not three phase. Each coil in this case is independently rectified, but he claims very good figures for ferrite magnets in this configuration.
Without iron cores, ferrites do a poor job in an axial flux configuration.
...........oztules
Dinges
Posted: 11:07pm 07 Jan 2010
[quote]I am wondering if there are other coil/ magnet ratios that produce no cogging?[/quote]
There is a lot of information in this site:
http://www.powercroco.de/rasten.html
http://www.powercroco.de/Kombinationstabelle.html
" Systeme die dem klassischen Aufbau folgen 3:2 (Grundwellen-Motoren - wie alle 2poler BL, 3 Spulen / 2 Pole N und S) 3:4 (2. harmonische Motoren mit 3 Spulen / 4 Pole, N-S-N-S)oder allgemein: 3n zu 2p oder 3n zu 4p,(6N8P; 12N16P)sind immer stark rastende Motoren.
Aus der Suche nach wenig rastenden Kombinationen resultierten dann die Motoren mit 12 Nuten und 14 oder 10 Polen (LRK), oder auch 9 Nuten mit 8 oder 10 Polen (CDR-Motoren).
Das trifft natürlich auch auf deren vielfache (18N16 oder 20P) zu!"
As he says, there are combinations that produce *less* cogging (no cogging doesn't seem to be possible using this technique)
http://www.powercroco.de/theorie.html
With apologies to the non-German speakers, but Tinker's name suggests a German-speaking heritage, so I assume he won't have too much trouble reading it.
Peter.Edited by Dinges 2010-01-09
GWatPE
Posted: 11:59pm 07 Jan 2010
Surely the benefits provided by NEO magnets is worth the effort to handle them with a bit of care during building, without resorting back to iron cores for DIY windmill applications.
become more energy aware
Posted: 01:13pm 08 Jan 2010
  GWatPE said   Surely the benefits provided by NEO magnets is worth the effort to handle them with a bit of care during building, without resorting back to iron cores for DIY windmill applications.
I agree Gordon, just thought there may be a way to make them even better with NEO magnets (especially the smaller ones I am playing with presently).
Dinges, thanks for posting that German article, you were right, I was raised in that language (in Austria) but it has been many many years since I dealt in German technical terms.
I did get the gist that its not quite as simple as I though initially, lots of factors come into play. I think with my motor its the rather small gap at the ends of the "hammerheads" on the rotor that reduces the cogging. The stator is wound & connected as the little calculator suggests.
I think the 11 coil/ 14 magnet ratio Oztules mentioned might be worth tinkering with. If it works well with ferrite magnets it could be even better with NEO's
