Local Time 10:54 05 Nov 2026 Privacy Policy
Forum Index : Windmills : What’s the best lowest cog motor around?
dvn8
Posted: 12:51pm 10 Jan 2010
Just wondering if there are any good motors for generator that has the high output with a low torque output or no cog?
Which type of motor will give out the lowest cog, axial, permentant mag, or other type of motors?
Dupa
Posted: 03:33pm 10 Jan 2010
I believe an AC servo motor has little to 0 cog.
I is a injenear
Perry
Posted: 09:53pm 10 Jan 2010
Axial flux PMA'a have zero cog.
Perry
KarlJ
Posted: 11:45pm 10 Jan 2010
Its almost irrelevant anyway, pole twisting reduces the cog on the f&P to almost nothing and they cost almost nothing.
AXFX =$1000++
AC servo motor = $$
7 Phase on F&P $100
(unless you have a spare 36pole magnet hub then free I guess)
P&P with poles twisted ~$30
If you're talking a mill big enough for either of these motors to make worthwhile output you need 3m+ blades
It all comes back to this simple problem
-in order to make power you need to have wind, if there isnt enough wind to overcome startup cog then there isnt enough wind to make any power of note.
