Local Time 00:12 10 Aug 2026 Privacy Policy
Forum Index : Windmills : Cast Iron Vs Steel
Sonny
Posted: 02:00am 10 Feb 2010
I am still trying to get the things together to build my turbine. I have some 1/4 inch material I can use for the magnet rotors. But I was over at my son's place the other day and he has some old weights he is getting rid of. I was looking at them and had this wild idea. The smaller weights are just about the right diameter for what I need for the generator. I can turn them in my lathe to get them to the right size plus help with the balancing. I'm sure they aren't balanced now because they are just cast and didn't need to be balanced for what they were intended to be use for.
My question is, will there be any difference whither I use the iron vs the steel rotor? I want to be sure I use the best. But like a lot of stuff I seem to hit a brick wall when it comes to finding the information I need. I know Hugh Piggott has used old disk break rotors but most of the kits I find are using steel rotors.
Thanks in advance for your help.
Sonny
a complete novice
Greenbelt
Posted: 03:06am 10 Feb 2010
Sonny;
Magnetic coils do not function well when used with Cast Iron. The very soft steel silicon type is best for magnetic coils because of the reluctance Factor, Cast iron is slow to magnetize , and it is slow to de magnetize when polarity reverses. I would vote against It. Sorry!
Look up Magnetic reluctance an permeability.
Here is a link that explains it better Edited by Greenbelt 2010-02-11
oztules
Posted: 10:29am 10 Feb 2010
Sonny.
If you are using the cast iron for rotors (I think you are) then that is fine. No problem at all.
If you are using them in an environment where changing magnetic flux occurs then see Greenbelts answer.
For an axial flux they are fine to use as rotor steel.
For a recipe that calls for mild steel, then cast will do the job just as well
..........oztules
Sonny
Posted: 02:07pm 10 Feb 2010
Thanks Oztules, you're right about using them for the magnet rotors.
And thank you also Greenbelt, that's a great web page. It brings back everything I had forgotten from my Ham radio days plus a lot more.
a complete novice
