Local Time 10:37 05 Nov 2026 Privacy Policy
Forum Index : Windmills : F&P distributers
Quail
Posted: 09:25pm 15 Feb 2010
I have not been able to get a hold of Randy from www.randysworkshop.com to see if he has any F&P motors left. Does any one else know a USA source for the motors at a cost comparable to Randy's?
KarlJ
Posted: 05:28am 16 Feb 2010
Motors from Me with shaft and Hub are
$50 plus $160 in freight!
if you like I have a 60S decogged and an 80 S rewired as 2x7P 1/2 star 1/2 delta remaining from the 30 I had.
Being USA you can have both, the bearing block (which randy doesnt have) and the shaft for $50 +post which is going to be about $180.
Bearings are good for 3m rotor and having 2 stators will give you a better range of output (hence matching to prop) not to mention almost double the output.
I wish I had another solution.
Karl
