Local Time 10:27 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Help, please!!! Windmill part
WindtonSandino
Posted: 09:13pm 19 Feb 2010
Hello everyone! My name is Norberto and I am from Argentina. Well, I have built my first windmill with a lot effort and help from very kind people. But I have been thinking for a long time about the way in which I can prevent the wires to get entangled when the windmill turns due to changes in wind direction. I know that this part has technical name but I don't know it. If you do please tell me so I can either built or buy one. Furthermore, If you know where I can find a layout to built one, better. The windmill is not that big (about 50W), but is the first one. Anyway, the design of this part is driving me crazy! Help!
Strange, but not a stranger.
montyLalor
Posted: 09:28pm 19 Feb 2010
Ahh, you're referring to "slip rings".
This link will help:
The Back Shed - Glenn's recipe for home made sliprings
Gizmo is The Man!
Good luck!
Luke
"So are you doin' this project to make us money or cost us money?" she asks again...
WindtonSandino
Posted: 09:51pm 19 Feb 2010
It does help!!!!!!!!!!! Thanks a lot!!!
KarlJ
Posted: 02:21am 20 Feb 2010
losses and maintenance are an issue for sliprings.
consider using a drop wire with a plug so you can periodically un twist the wires. 0 cost and more reliable.
MacGyver
Posted: 04:37am 20 Feb 2010
My latest build is not flying yet, but I'm working on "stops" set 180-degrees apart, so the windmill will not "yaw" (rotate horizontally about the tower's axis) past either side.
My wind is fairly consistent, coming from the west mostly. I'm not going to worry about small intermittent direction changes.
Doing it this way, I'll have the down-wire strapped to the tower and won't have to worry about tangles. As soon as I have it up and flying, I'll post pictures.
. . . . . Mac
Copeville, Texas
Perry
Posted: 07:41am 20 Feb 2010
Mac,
Why not have one stop so the turbine could rotate about 350 degrees. I am starting to wonder if full unlimited yawing is necessary given the predominant wind siting for most turbines.
Perry
KarlJ
Posted: 07:45am 20 Feb 2010
indeed thats the go.
WindtonSandino
Posted: 09:37am 20 Feb 2010
Ok. Nice! Now I am having different points of view on the same topic, which really widen my perspective on this matter. Thanks to everyone! and keep discussing! It is really nice to read your discussions. Thanks once more!
GWatPE
Posted: 11:15am 20 Feb 2010
When there is a stop, there will always be a time when the wind is coming strongly from a direction where the mill is up against the stop, and at this point furling is no longer possible, and the possibility of the windmill becoming uncontrollable will arise. I would never place any restriction on the yaw ability of the windmill head.
Gordon.
become more energy aware
Perry
Posted: 01:46pm 20 Feb 2010
Yes, Gordon, I hear what you are saying and I recognize the importance of preserving furling but do you really see strong winds occurring from all different direction? My statement is based on my observations at my 'limited' wind site but there is a predominant wind direction for me and usually only small amounts of wind from other directions.
Albeit the pendant tangle issue may not really be an issue but could this not be an area to simplify?
Perry
WindtonSandino
Posted: 05:25pm 20 Feb 2010
I woundn't put any restricition as well. I believe that the windmill should always be free to move to face the wind, specially if you are in an area with small amounts of wind.
Windton
kalamidas
Posted: 07:38pm 20 Feb 2010
Hello Windton i made a windmill of an ametek motor
it is about 120w and i use a thik microphone jack
at the cable inside the pole male at the generetor side and female at the controller side. and it turns for six months .if you go with this remember a lot of grees in the jack and a lot of duct tape with some tireups in the back where the cable meets the jack,so it does not tear it apart.
it easy fix.
Best
MacGyver
Posted: 06:35am 23 Feb 2010
[Quote=Perry]Why not have one stop so the turbine could rotate about 350 degrees.
I gave this idea some thought, but my thinking is if I give it too much room, it may get up enough speed to do some serious damage to the blades when it yaws for 250 degrees or so and slams to a stop.
I think stops at the ends of a semicircle gives me more of a chance and if the wind does a 180 on me, the mill will run backwards (not likely) which would still work.
I'm still working on the alternator, so it'll be a while. When it happens, I'll post a video on you tube. I've almost got the alternator built. It's been a project with a capital "P" -- lots of work!
[Quote=Gordon]I would never place any restriction on the yaw ability of the windmill head.
Point well taken, however, all my stuff is really small. I'm only after a 12-volt battery charger. If my windmill gets away from me, it's swept area is not large enough to get out of control and do any damage. You folks with 17-foot wooden blades are a different matter. So far, the only scary thing any of my (recent) mills do is siren a little as wind spilling off the rotor is cut by the tower (keeps the neighbors guessing!).
. . . . . Mac
Edited by MacGyver 2010-02-24
Copeville, Texas
DTMC
Posted: 12:11am 24 Feb 2010
Hi everyone,
My first thought regarding stops is don't do it after seeing a big old Southern Cross brought down by a restriction on its ability to yaw.
These should be suitable for small to medium sized turbines. It should be noted that I have not used this particular product.
http://www.mercotac.com/html/335.html
Without slip rings it might be better to leave the mill unrestrained by stops and use a plug that will pull out if the cables wind up excessively. This is the method I use on my test tower (which is at a turbulent site) and I am yet to have a problem with it. I use individual cables for each phase which will wind around each other easily. Multi cored three phase cable can get a bit ugly because it doesn't like to twist.
FWIW, I make my own slip rings from brass, fibreglass, epoxy and large electrical motor brush holders for permanent installations.
Perry
Posted: 12:19am 24 Feb 2010
But if they pull out you will lose the ability to shut down the turbine when you need it most.
Perry
DTMC
Posted: 12:47am 24 Feb 2010
That is true, but with the setup described, it will need to become a proper mess before it pulls out so there is plenty of warning. There is a good chance that the cable will go a year or more before it needs any attention.
Don't know about you guys, but I like to do a walk around every day or two (when I am home) to check for problems and damage - it is usually the cockies getting into cables.
Anyhoo... The point of my post was the link to a readily available slip ring.
It seems that there is a board member (and a very bright chap by all accounts) already using one of these.
http://www.mindchallenger.com/wind/wgpage10.html
WindtonSandino
Posted: 07:55pm 07 Mar 2010
Thanks Kalamidas! that is a very nice idea that does help. In fact, I should say it's wise and simple, and it meets my needs. Thanx once again.
