Local Time 01:38 05 Nov 2026 Privacy Policy
Forum Index : Windmills : first windmill
wainfleetwild
Posted: 02:46am 08 Jan 2011
i am new to wind power and am going to try my luck at building my first windmill . i decided to use a pm dc motor , my question is have i got the right one ? it's 90 vdc , 1750 rpm , 5 amp . is the rpm to high , or amps to low . any help would be appreciated .
Downwind
Posted: 03:25am 08 Jan 2011
If im right (and i could be well wrong here) you take the 1750 rpm and divide it by the voltage, then times that by the voltage you require to get the operating rpm of the mill.
So......
1750 / 90 = 19.4444
19.4444 x 14 volt = 272.22 rpm
You should get 14 volt at 5 amp at 272 rpm.
Should be reasonably practical for a 12 volt system, but might not be so good for a 24 volt system.
Pete.
Sometimes it just works
wainfleetwild
Posted: 12:37am 24 Jan 2011
thank you downwind
gsw999
Posted: 10:41am 24 Jan 2011
I have played around with a few differene motors ametek etc the best one seems to be the indiana, hopefully playing around with this will give you the oomph to build your own turbine from scratch :)
i am not interested in giving my hard earned money to corrupt "leaders" to pour down the drain.
