Local Time 01:37 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Vane Weight
Bobden
Posted: 07:49pm 05 Feb 2011
Hi all I am building a self furling wind turbine all going well. Have tried to calculate the weight for the vane to furl at 10 ms ( 22 mph ). The answers I get are ridiculous and obviously wrong. Can you help me out, the info for my turbine are
Blade diam .62mm
Head off set .05mm
tail length .6mm
Furling speed 10ms (22mph)
Vain area .1134 sq m
Pivot angle 20 deg
Any help would be great full as it driving me mad. I must be doing the same mistake each time.
Regards Bob
Greenbelt
Posted: 05:52am 06 Feb 2011
Have some confidence, It'l come to ya.
fillm
Posted: 09:24am 06 Feb 2011
Bob,
By the dimensions you have quoted, this turbine would almost fit onto a match head .
Hope you are not expecting a lot of power from it .
Bobden
Posted: 10:34am 06 Feb 2011
Phill
Thanks already I have quoted the blade radius, the blade diameter should be 1.24m.
Bob
Greenbelt
Posted: 07:10pm 06 Feb 2011
Hi Bob;
You have several mistakes on your post or it may be a joke in poor taste.
I will assume that you do not have the (Metrics)and decimals figgered out. I have a
Neighbor friend who is a good mechanic but he has a problem (Dyslectic from birth) keeping his numbers in order.
Review of your post.
Item # 1, Blade diameter .62mm. (when reading this, It says dia. is slightly more than one half of one millimeter. This is the size of a sewing needle, rather small for a turbine. On your second post you have given a diameter of 1.24 meter which is reasonable to discuss but still a bit small for the average. There is 1000 Millimeters in 1 meter, So your blade has a diameter of one thousand two hundred and forty mm.
Item#2
Head offset,.05 mm. This is smaller than the bearing clearance in an engine, even
(.5 mm) one half a millimeter is way too little for an offset. But .05 meter would probably be a working number, 50 mm., Philm could tell you better than I.
Item # 3
Tail Length, .6mm. again very small, .6 meter, (.6m )not mm. is close to the size you would need for your small turbine. .6 meter is 600mm.
Item # 4
Furling speed you have spot on numbers.
Bobden
Posted: 08:09pm 06 Feb 2011
Hi Greenbelt thanks for the input, first its a joke then I am dyslectic. Yes I made a mistake but it is plainly obvious I meant meters or part of a meter. Just to let you know I have figured it out without your help, but then my turbine is small on average so not worth bothering with. Still thanks for making up my mind that I will never ask for help again, thanks to sanctimonious armchair experts like you!!!
Bob
Greenbelt
Posted: 10:12pm 06 Feb 2011
Hi bob,
OK.Edited by Greenbelt 2011-02-08
brucedownunder2
Posted: 10:22pm 06 Feb 2011
You'll be OK ,Bobden. Just hang in there ..
We are a strange mob over this way ,sort of take the mickey out of anything..
keep talking and asking questions
Bruce
Bushboy
Greenbelt
Posted: 08:06pm 07 Feb 2011
Hi Bob
I must apologize for the remarks in my previous post, After reading it over it does have a snotty sounding attitude.It was not intentional. the intent was to point out the importance of posting correct information so that a meaningful answer can be provided. I admit to being suspicious of whether your post was a real request for assistance or a prank. There are many people who get their cookies by logging on a web site and post something to generate friction.
Good luck on your project. Regards, Roe
VK4AYQ
Posted: 01:32pm 08 Feb 2011
Hi All
Confusion caused by an extra m.
Hi Bobden
We all should laugh at our mistakes, I have a similar problem with metric, being brought up on the imperial system, remember if we can't laugh at ourselves then somebody else will do it for us.
All the best
BobEdited by VK4AYQ 2011-02-09
Foolin Around
MacGyver
Posted: 05:36pm 08 Feb 2011
Bobden
Assuming you're still around, I too build "toys" (read that "rather small stuff") and I as well have taken a lot of "pot shots" from the crew here; it happens. Just grin and bear it.
I plugged your diameter of 1.24 meters into Alton's Calculator and you can expect nearly 100 watts at an rpm of around 800 or 900 if your windmill is coupled to a working generator. At that rpm, furling is not so much a problem, but if you wish to make it do so, simply build a post at around 45* opposite to the side the alternator (generator) is mounted, so they are each on a side opposite the yaw point. That means the generator is on one side and the tail is on the opposite side.
The tail will "hinge" about the post; just make it a few feet (a meter) long and try it out. Be sure to put a "stop" so if the thing furls it doesn't wipe out your blades altogether. The tail should furl towards the side the generator is mounted. I saw a post on Youtube where the guy made the post angle so steep, the tail actually furls "above" the blade path, so he didn't need a stop, but most folks use a stop and let the tail furl within the region of the blade plane.
I've found that trial and error is a very valuable tool. Try it for yourself and when you come up with a winner, post your results on the 4m for others who will surely follow.
. . . . . Mac
Copeville, Texas
