Local Time 00:30 05 Nov 2026 Privacy Policy
Forum Index : Windmills : charge controller off ebay
arklan
Posted: 01:03am 16 Feb 2011
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=2805938166 39
i bought this item because i thought it would be a charge controller and inverter in one but its just the charge controller :p
by the sounds of it, it would just let the windmill freewheel when the battery is full, so im trying to think of a way to have it working without too much losses from a dump load controller :S
it can only handle 30 amps at 48v so im pretty disappointed.
the way its described made me think it came with a 1600watt inverter with the charge controller.
but im not gonna let it go to waste so its time to get crackin
VK4AYQ
Posted: 06:56am 16 Feb 2011
Hi Arklan
Tried to check it out but it has been removed from fleabay.
Could you post the details so maybee we could help.
All the best
Bob
Foolin Around
KarlJ
Posted: 12:24pm 16 Feb 2011
30A at 48V is a fair chunk more than a dual F&P will ever do, so you'll probably find it adequate for a couple of projects in a battery charging situation that would be more like 30A at 58V =1740W -pretty much a 2KW+ mill.
this is a fair controller depending on how much you paid for it of course.
loose the space and you'll get it up Bob
try this http://www.raumenergy.com/battery_charger.html
Edited by KarlJ 2011-02-17
KarlJ
Posted: 12:34pm 16 Feb 2011
their 3.5KW mill looks great hmmm downwind :)
redbullalan
Posted: 03:00pm 16 Feb 2011
Hi
get a pic up of the controler so we see what it looks like cost and what you think of it.
i hope if we all do this may help each other out
alan
Reddbull alan
