Local Time 00:29 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Ceiling fan power input. help
redbullalan
Posted: 08:36pm 08 Mar 2011
Hi all
Looking for some info i have 2 dc mother mills but also built a ceiling fan mill around 50v 1 amp per coil 2 coils
Set them up with a bridge rectifier dc out pit now
What i would like to know can i just connect it up to my battery bank 12v set up.
Or will i heed to hold back the voltage to 13 – 16 volts with some kind of regulator will putting 50 60 volts at low amps into a battery go bang.
i know i will need to connect it to my dump conrtole but what about the exra power
thanks for looking
alan
Reddbull alan
VK4AYQ
Posted: 11:05pm 08 Mar 2011
Hi Allan
Put a 3 to 1 transformer in before your rectifier to get a better match to the batteries, you could connect direct as the battery will load it down but it will be overloaded and not efficient, a bit like driving your car in top gear all the time.
All the best
Bob
Foolin Around
redbullalan
Posted: 06:55am 09 Mar 2011
Thanks for the info
how would i get hold of one or make one new to this
thank you for your time
Reddbull alan
MacGyver
Posted: 05:30am 11 Mar 2011
rebullalan
Just a quick note here: In order to charge a 12-volt system, your alternator's output will have to be in the range of 14 volts or so. If it goes higher, the system will "clamp" the voltage to 12 volts. However, if your output voltage is very much higher (like you said -- 50 volts), it will heat the coils in your alternator and try to cook it, so you want to not go much beyond about 14 volts, if you can help it.
The rectifier will change the alternating current into direct current and you can likely buy one online for not too much, but what you'll want to consider first off is to decrease the number of windings in your two coils so they produce less voltage. The reduction in windings will give you more space, so you can increase the size of the wire used, which will decrease the coils' resistance and subsequently increase your amperage.
I might add that using two coils is going to thrash around a bit at high speed. It would be better to have enough coils to allow you to utilize what's called "three-phase" windings. These are gathered together in either of two popular methods (called "star" or "delta" by most folks here) before they are connected to the rectifier.
I know that's a lot of stuff, but just take it a step at a time and you'll be fine. There are oodles of posts from lots of people more knowledgeable then I on the 4m; look around.
Oh, and by the way, welcome to the 4m!
. . . . . MacEdited by MacGyver 2011-03-12
Copeville, Texas
