Local Time 23:35 04 Nov 2026 Privacy Policy
Forum Index : Windmills : Its back up!
frackers
Posted: 12:32am 01 Apr 2011
Three days before Christmas we had a fair old storm come across Canterbury and the 120KM/hr winds took out my 3m axial mill by precessing up the stub mast until the whole assembly came off its pivot. Who would have thought that it could lift 50kg by 300mm!!
The repairs required the following work:
* New blades (the old ones were spread up to 85m from the tower)
* new stub mast (bent where the blades hit it)
* new magnets (one set of 12 on the front rotor had lost over 70% of their magnetism - cause unknown)
* new tail metalwork (the old one was too heavy)
* powder coating on the magnet rotors (they had got very rusty under the magnets)
The new blades have the pitch going the opposite way to last time, to reverse the rotation, so if the whole furls quickly whilst going at full tilt it won't precess off the stub mast again. They are also lighter being made from western red cedar rather than old remu joists
Other work was just refurbishment:
* stripped and greased the hub bearings
* new connectors on the three phase cable dropping down the tower.
The stator and generator frame escaped unharmed so not bad for a big event after nearly 3 years in the air!
Robin down under - or are you up over
windlight
Posted: 03:25am 01 Apr 2011
Always sad when something crashes but it does give you an opportunity to refine things, and stay away from them earth quakes.
Allan
shawn
Posted: 05:49am 01 Apr 2011
Great news now I have something to watch when I have my tea break
It was always a nice mill
VK4AYQ
Posted: 12:23pm 01 Apr 2011
Hi
There is something hypnotic about watching a wind turbine spinning away and hopefully making a few amps to boot.
Ongoing improvement is dependent on such events sad as they are but the opportunity for improvement is thrust upon us.
All the best
Bob
Foolin Around
VK4AYQ
Posted: 02:24pm 01 Apr 2011
Hi
All the best
Bob
Foolin Around
frackers
Posted: 02:58am 02 Apr 2011
  windlight said   ... and stay away from them earth quakes.
The (September) earthquake is why I've rebuilt it - nothing can replace that feeling of security when the ground is moving all the time, the power is out and you haven't slept in I don't know how long but the domestic water pump and the freezers have power!! Wasn't until I got back to work I discovered we're only 2km from the surface fault and 6km from the epicentre :(
I didn't think the system would ever pay for itself and it won't in monetary terms but the satisfaction of having it there when I needed it surpasses all that dirty old cash :)
KarlJ
Posted: 02:54pm 02 Apr 2011
I had the yaw bearing tear out of the head assembly and although no damage was done it took some time to get it all back up and running.
In fact was a significant reason I drove to Melbourne from Perth (tools)
As rewarding as the first time it is absoluletly majic throwing the switch
and within a few seconds turning slowly, finding the wind then spinning up and punching the power in..
You are not alone, All of those things are worth more than the sum of the parts the feeling is priceless.
Nice one.
-now how about some pics?
JimBo911
Posted: 02:20pm 06 Apr 2011
Frackers
Some guys in the US (because of poor vision) cant see all the way to New Zealand some photos would be nice. Congrats on your rebuild.
frackers
Posted: 11:14pm 06 Apr 2011
  JimBo911 said   Frackers
I've not had a chance to sort out pictures from the end of the rebuild but the start of it is on my website.
The original build is here with details about the controller and mast.
The current state of the system is here which updates every 5 minutes (although the data is gathered twice a second)
