Local Time 21:18 04 Nov 2026 Privacy Policy
Forum Index : Windmills : Neo Magnet Pricing
Trev
Posted: 09:34pm 01 May 2011
Neo magnet pricing has been climbing rapidly.
Here is a snippet sent to me fom a supplier in China.
"The raw material market of neodymium magnet is still not optimistic since we wrote you in February. Especially, the price of Neodymium & Dysprosium has surged recently. For Dysprosium, from USD462/KG to USD647/KG; for Neodymium, from USD69230/TON to USD123077/TON."
The graphs were also sent to me and are taken from http://www.asianmetal.com/price/initPriceListEn.am?priceFlag =8
but the average jo can't read the information. Here I have copied the graphs showing the price climb on raw materials. Date on the bottom and price on the left side of the graph.
Neodymium
Dysprosium
The current price in China for N50M is USD$25 (20 April) in quantities of 100 or more. Look at the graph, the price is now higher than that, today (2 May). Tommorow the price will be higher.
Trev @ drivebynature.com
MacGyver
Posted: 09:38pm 02 May 2011
Trev
Guess that means I should use up the zillions of neo-mags I have sitting all over my shop, eh? I can't believe all the magnets I have; I could build a statue with them all!
. . . . . Mac
Copeville, Texas
niall1
Posted: 07:25pm 23 Jun 2011
price increase is filtering down here now....
a set of 24 block neos ex postage was 98 euros (132 oz dollars).....now 215 euros (291)....
up by 2.2 times ... Edited by niall1 2011-06-25
niall
vawtwindy
Posted: 11:23am 24 Jun 2011
does that mean switching back to ferrites will help? oztules already showed the way.
mac46
Posted: 11:36am 24 Jun 2011
vawtwindy,
Welcome to the forum,
Depending on you'r meaning of the word "help", Ferrites will yeild 1/3 to 1/2 the power output vrs neo magnets, but at a much lower costs, and as I understand it the ferrits will continue on for several years vrs the neo mills wich seem to have corrosion problems as well as the tendency to burn out the mill when spun to fast during a high wind event. This is my understanding anyway, others may want to add their experiances.
...Mac46
I'm just a farmer
vawtwindy
Posted: 11:46am 24 Jun 2011
thanks Mac46,
"corrosion problems" yes i have read this issue in fieldlines on Neo's, and started hunting the info on ferrites, again hugh's work on AWP and Awp team have done marvellous job on it.
vawtwindy
Posted: 03:16pm 27 Jun 2011
soon ferrite prices will also shoot up
Ni45Co5Mn40Sn10
The multiferroic alloy, with the catchy name Ni45Co5Mn40Sn10, was created by combining its various elements at the atomic level. Multiferroic materials are known for having unique elastic, magnetic and electric properties, and in the case of this alloy, that takes a form of an usual phase change. When heated, the non-magnetic solid material suddenly becomes a strongly magnetic solid
http://www.gizmag.com/alloy-converts-heat-into-electricity/1 9025/
electrondady1
Posted: 12:05am 03 Jul 2011
i can see no reason for ceramic mags to go up in price.
the materials used are widely available
i think it's mostly industrial waste
if china tries to pull something funny,
someone else will gear up to produce and undercut them.
Trev
Posted: 08:52am 03 Aug 2011
This whole thread should have been in the price watch section. Sorry Glenn.
I was just looking at the Aussie magnets website that Glenn posted specials page of in the price watch section.
I had a look at the website and compare some prices of 50mm diameter x 12mm thick. They have a N42, but don't say what temperature rating. http://aussiemagnets.com.au/product/-50mm-x--12.7mm-Disc-%28 Rare-Earth%29.html
I knew they were going up, but can you believe $50 each. My N50's ($15) just went up. No, really I am going to keep them all.
In fact no one would want them now anyway. The last lot I sold came back with pit marks on them. I think it must have been some issue with original packing causing the pit marks. All I have in stock are like this now.
