Local Time 21:18 04 Nov 2026 Privacy Policy
Forum Index : Windmills : Optimum angle of guy wires?
domwild
Posted: 11:08pm 17 Jul 2011
Is there an optimum? If it should be 45 deg., then the distance of the mounting point on the dirt from the mast would have to be the height of the mounting point at the top of the mast.
Thanks.
Winston Churchill
niall1
Posted: 11:29pm 17 Jul 2011
hi Domwild
45 degrees does sound nice ,i tried to get mine close to that but its a small mast so not to hard for me to do ...i used up whatever space i had ..45 seems good for the winching anchor as well
but as you say its still a big foot print ...even on a small mast
if you can go out to 45 i think it means a slightly lighter choice of stays can be used as the force/stress,s are better distributed ? ....
its an interesting question ...the optimum 45 ?....the minimum x per height ?....
Edited by niall1 2011-07-19
niall
Posted: 11:35pm 17 Jul 2011
I think it has a lot to do with ground conditions, the guy wire anchors and the tower footings and too. If its loose soil, then further out would probably be the way to go. If its rock, then you could go closer to the tower, so long as you know how to anchor into rock correctly.
niall1
Posted: 11:50pm 17 Jul 2011
good point...
mine was,nt to bad ...undisturbed heavy ,thick dry,sh clay ,but everybody's got different conditions , we also have plenty of shallow boggy soft stuff here as well ...that,d be much more of a problem
if your in doubt ,its comforting to hire a local guy with a mini digger for a few hours ...its a one off job and they,l usually have a slim bucket to make a nice neat deep trench .....they,l refill the anchors ,flatten and in a couple of weeks any traces of the digger will be gone ...
erm... ..my mast and stays are so low it doesn't add up to more than a hill of beans ...only wish it could be higher ....
niall
VK4AYQ
Posted: 01:49am 18 Jul 2011
Hi Dom
I like to use the ratio 3-4-5 as it makes the job of getting length of the guys easy
4 is the height 3 is the splay and 5 is the guy length, makes a good strong set up to.
Bob
Foolin Around
domwild
Posted: 06:07am 18 Jul 2011
Thanks for all the answers. 3,4,5 makes a right angle and is steeper than 45 deg. 53.1 deg. if my maths is right.
Winston Churchill
VK4AYQ
Posted: 07:03am 18 Jul 2011
Hi Dom
Having a good anchor point is more important than the actual angle as a few degrees this or that way makes little difference, as the mid point guys are more than 45 degrees anyway.
All the best
Bob
Foolin Around
windlight
Posted: 10:00am 22 Jul 2011
The top and second top wires are the workers.
