Local Time 10:33 08 Aug 2026 Privacy Policy
Forum Index : Windmills : operating temp of n50 mags
Hugh
Posted: 06:39am 24 Jan 2007
buying a hundred lot of N50s,( 2by1by1/2 inch ) & these are the specs they gave. Its all greek to me however the working temp concerned me does this seem right.
Hugh
Br:1400-1450 (14.0-14.5) mT/(KG)
Hcb:>=860(>=10.8) KA/m(KOe)
Hcj:>=955(>=12) KA/m(KOe)
(BH)max:382-406(48-51) KJ/m3(MGOe)
Max working Temperature: 80 ℃Max working Temperature: 80 ℃
thnxs allways
Megawatt Man
Posted: 03:08am 26 Jan 2007
G'day Hugh, I'll bet that's 80 degrees Celsius. I reckon you don't get many days at that temp in your part of the world, maybe even 80 degrees Fahrenheit!
Megawatt Man
Hugh
Posted: 11:51am 26 Jan 2007
hey there Megawatt
Its dam cold right now, a balmy -17C. I think the supplier was referring to the temp where the mag starts to loose its charm (mag wise), is this a gradual decline or more like a switch. is this
Hugh acceptable
thnxs allways
Posted: 12:03pm 26 Jan 2007
Hi Hugh
I think that temp is the safe max working temperature. Any higher and the magnet will start to loose its strength. There is a temperature above this where the Neo magnet will basicaly drop its guts and loose all it magnetism.
So keep it under 80c and you should be fine. In a windmill it should never go anywhere near that temperature.
Hugh
Posted: 12:10pm 26 Jan 2007
thats the ticket gizmo, there's a word for the drop its gut temp. but it escapes me
Hugh
thnxs allways
vawtman
Posted: 07:34pm 26 Jan 2007
Hello Hugh
Are you referring to the currie temp?I did a test comparing neos to ceramics by attaching them to a woodstove.It wasnt long and the neo just fell off and the ceramic was unaffected even near the coals.Has Gizmo stated that unless they rub on something you should be fine for turbines.
When they lose it hardly any noticable magnetism is left. v......
Hugh
Posted: 09:13pm 26 Jan 2007
thats the word & it was in your posting that I saw it
Thanx
Hugh
thnxs allways
Megawatt Man
Posted: 11:45pm 26 Jan 2007
G'day all, Yes, the info now posted is right. The name Curie is after Pierre Curie who did a lot of early work on magnetism. His wife Marie was the lady who together wih Pierre isolated radium and other radioactive elements. Pierre died in a road accident and thereby escaped death through radioactivity, the fate of his good lady.
Megawatt Man
