Local Time 14:47 05 Nov 2026 Privacy Policy
Forum Index : Windmills : plans for a solar collector
Hugh
Posted: 12:14pm 25 Feb 2007
very detialed
http://www.ida.net/users/tetonsl/solar/page_iii.htm
thnxs allways
Posted: 09:23pm 26 Feb 2007
Thats a good set of plans, very pratical. If only there was a cheap and easy way to convert heat directly into electricity. Has anyone ever played around with those peltier effect units to generate power?
AllanS
Posted: 09:53pm 26 Feb 2007
Cooled triple junction solar cells are pushing 40% efficiency at 500 sun concentrations. They cost a mere $100000 / m2.
If insolation is 200Watts/m2 (averaged over 24 hours), a 500m2 mirror focussed on this solar cell might generate 30kW/m2, or 260000 kW/hours/year. At $0.1/KW/h, this would sell for $26000. Add to the cost of the cells, you've got the cost of the mirrors, electronics, distribution, upkeep etc. I reckon by the time it's paid off, you're ready to replace it.
Hugh
Posted: 11:42pm 26 Feb 2007
another alternative and a use for all that heat
http://www.junkyardsolar.com/Edited by Hugh 2007-02-28
thnxs allways
whirlybird
Posted: 11:57pm 01 Mar 2007
This is just a quick question maybe for gizmo.
Why can you not directly click on the links on some or any of the pages.
Not trying to be critical of the back shed or its managment
Best regards to all.
Bob B.
I am because I am.I am not always right but often I am.
Megawatt Man
Posted: 06:08am 05 Mar 2007
It's because they're not posted as links, I reckon. Just copy and paste.
Megawatt Man
Posted: 07:18am 05 Mar 2007
Hey whirleygird, I did mean to asnwer your question, but completely forgot about it. Thanks to Megawatt Man for posting a message, kind of reminded me.
Yes, if someone just pastes the link, they dont work as a hyperlink when everyone views the posting. But see the buttons above the box where you post a message, the 4th from the left is the Add Hyperlink button ( if you hold your mouse above the buttons for a second it will tell you what it does ). If you click on that when posting a message, it will ask for the text, and then the actual link. So you could use "here" for the text and the web site address for the link. I just paste the link address into both area's.
Sometimes I will edit a posting to change the pasted links to hyperlinks, but thats kind of rude of me so I usually leave them alone.
