Local Time 12:32 04 Nov 2026 Privacy Policy
Forum Index : Windmills : F&P setup
DuvalAppliance
Posted: 03:31pm 27 Oct 2012
OK what is the best setup for across the board power should i go the delta config..? or is there a better setup I have the new style rotor and stator so i can wire it however needed i have some great ideas but i need help... and once its setup and making power how do i store it? the sell it back to the electric co..
and if i have 2 rotors and stators to setup how many watts will i get from each setup?
Please send me in the right dir....
thank you
Newbe William
Posted: 07:21pm 27 Oct 2012
Hi William
Will need some more infomation. What voltage do you want to run the system at? If its a grid tie inverter you plan to use, what model?
As a rule, you can expect a watt per rpm for a F&P. So at 200 rpm, you can get 200 watts. This rule can be bent quite a lot, but its a good starting point for a beginner.
DuvalAppliance
Posted: 03:30pm 29 Oct 2012
ok 12 volt system i have no idea of what i will need but i will spen the money to make it right... i have 4 of the f&P rotor and stators's waiting on me to set them up....
I have room for lots of them to setup and can get more of them so i can sell the power back and that is what i am looking to do.
I would like a VERTICAL one but need to find cheep parts
govertical
Posted: 03:31am 23 Nov 2012
Hi, I am working on a F&P project, how many coils are on the stator?
just because your a GURU or forum administer does not mean your always correct :)
mac46
Posted: 06:48pm 23 Nov 2012
William,
You stated that you need to be advised to the set up...
Going with vertical may not be you'r best choice right now. A horizontal mill or mills would be quicker/easier and produce more power for the investment. This may be better for you until you become more versed with the systems and capibilities.
12 volt may not be the optium voltage either, most are changeing over to 48 volt systems...just depends on what you want to use the power for / how you store it / how far away the tower...(towers)...are from the batteries. Most towers need to be above 50 feet, depends on you'r conditions, but clean linear air/wind is much better above 100 feet.
Just my thoughts...
Mac46
I'm just a farmer
