Local Time 14:31 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Other vawt’s
mossy
Posted: 09:07am 12 Jun 2007
I very much like the look of the Lenz turbine, but I'm wondering if anyone can tell me more about the drum-type, as shown below. I don't know what they're called. How do they compare with the Lenz in what counts, eg slow startup, reliability, and whether you can leave it running when you're not around? (I have a "hobby farm" 2 1/2 hours away).
Also I'm interested in what is the right kind of generator or alternator for feeding power into the grid, which is what I want to make my generator for.
Thanks,
SteveEdited by mossy 2007-06-13
vawtman
Posted: 04:31pm 13 Jun 2007
Hi Steve
Its made by Pacwind and believe this model is called the Seahawk rated at 10kw.
I love it.
Would be hard to homebrew however.
Its running a geared up axial flux now but im sure one could gear up a motor to grid tie.The very high solidity will limit its rotational speed in high winds i think and with the airfoil shape of each blade instead of being just thin steel(attic ventilatorish)It should develop high torque to keep turning when things fire up.
My thoughts for ya
mossy
Posted: 06:25am 14 Jun 2007
Thanks Vawtman. My interest in the drum-type is partly that they seem to vary considerably in the different shapes I've seen so it must be fairly forgiving in terms of design. The one I showed is not even as high as the diameter, wheras the Pacwind one is very high and narrrow. Also you see them with curved vanes and straight ones etc. For that reason I figured it would be easier to get it right, and it seems structurally simple. I have the aluminium siding from an old caravan (the American word would be "trailer" lol) which would be ideal for a drum-type. I think I'll give both of them a try and see which one wins.
Steve
vawtman
Posted: 12:23pm 14 Jun 2007
Oops, http://www.pacwind.net/ its the alpha series and not the seahawk.
Have fun with your projects Steve
