Local Time 22:08 07 Aug 2026 Privacy Policy
Forum Index : Windmills : delta wiring on F & P
F&P murray
Posted: 07:30am 19 Nov 2005
Glenn has avery good rewiring schematic on rewiring an F & P into 7 two pole star and then star/delta, is there a a diagram similar that shows delta wiring only, has any one got one.
Bob from Murray Bridge, SA
ozetrade
Posted: 10:23am 20 Nov 2005
Hi Bob,
I haven't seen any diagrams other than what's in the Eco Innovation manual.
It's a fairly straight forward process though. Start anywhere. In a clockwise direction, put the numbers 2-1 on the first post, 4-3 on the second post, 6-5 on the third post. Repeat this all the way around the stator.
Cut all the wires. Join all the wires numbered 1 and number the end wire No.1 when done. Join all the wires numbered 2 and number the end wire No.2 when done. etc. When finished you should have 6 wires numberd 1-6.
Join 1 & 5 - join 2 & 6 - Join 3 & 4. DONE
Greg
Just North of Brisbane in Redcliffe
OZeTrade.net
F&P murray
Posted: 09:08am 21 Nov 2005
Thanks ozetrade,
i will rewire a unit this weekend and see what i can get, im lucky i have a sh*t load of wind here having destroyed unit 1 already pictures to come on monday.
theres cheap power in gas but you have to sit on a vessel to collect it.
Bob
