Local Time 04:36 04 Nov 2026 Privacy Policy
Forum Index : Windmills : seemingly low power output
Goodz
Posted: 02:40pm 27 Dec 2014
Hi all Have wired up my F&P 7 phase 2x3C and have it working for 24 volts.
I am at this stage only getting up to 1.2 amps This is single F&P with old poles and new rotor (bought) on wind turbine with 1.2 metre blades. interested in Bruce's thoughts as to What this wiring configuration should put out have wired this way to try and get best Amps but seems lacking something. Have now wired one 1X6C which is to get more volts not amps
any help!!! OK
Goodz Edited by Goodz 2014-12-29
Posted: 04:02pm 27 Dec 2014
Hi Goodz
What type of blades, and whats the total diameter of the turbine. Do you have a wind speed measurement while you were getting 1.2 amps?
Goodz
Posted: 04:33pm 27 Dec 2014
Hi Glenn Blades are 1.2 metres dia 3 blades made from PVC pipe 160mm OD
No wind measure but about18-20 KPh
Goodz
Goodz
Posted: 04:38pm 27 Dec 2014
Although it runs well suspect blades may be too long made from (Wind and Wet) blade design
Posted: 05:39pm 27 Dec 2014
Hi Goodz
Yeah maybe a bit small? Aim for a turbine 2 to 2.5 meters diameter for a single stator. If you dont have much wind, try the 1X6C configuration, less max amps capacity, but will be making amps in lower winds and will give more watt hours at the end of the day.
Goodz
Posted: 08:44pm 27 Dec 2014
Thanks for your help will try these things
Goodz
