Local Time 04:36 04 Nov 2026 Privacy Policy
Forum Index : Windmills : fisher paycal hyro power
trout
Posted: 12:48am 02 Feb 2015
Hi guys could I get 240ac from a fisher and paycal genset then charge my battery bank with a ctek charger?
Ive heard it is to dangerous can someone explain if this is s
Downwind
Posted: 01:04am 02 Feb 2015
So what part of death by electrocution dont you understand as being dangerous ????
Sometimes it just works
trout
Posted: 01:25am 02 Feb 2015
Just want to know in laymans terms
fillm
Posted: 12:40pm 02 Feb 2015
Trout,
Why don't you just rewire the stator and run the AC output through a 3 phase bridge rec to make DC and then you can charge your batteries Fast or Bulk stage ..... up to a point or if you are mucking around with stuffed batteries then no .
Its a lot less dangerous than playing with unprotected higher voltage AC.
And its.... Fisher Paykel
VK4AYQ
Posted: 03:05pm 02 Feb 2015
Hi trout
Electricity is dangerous stuff it makes a good slave but a bad opponent, it is better to learn at lower voltages, below 60 volts, but even that voltage can kill or inflict bodily harm under the wrong circumstances.
In answer to your question, yes you can, and is it dangerous, yes it is, and the conclusion drawn, is that, if you have to ask is it dangerous, shows that your skill level isn't up enough to play with high voltages, but do not despair because we can all learn new skills, so start with gaining experience and confidence at lower voltages that will not kill or maim even if we stuff up a bit.
Remember the golden rule to keep one hand behind your back.
All the best
Bob
Foolin Around
