Local Time 04:35 04 Nov 2026 Privacy Policy
Forum Index : Windmills : motenergy me1016 pm generator
trout
Posted: 10:35pm 03 Feb 2015
Hi there is this a quality hydro generator?????
davef
Posted: 11:42pm 03 Feb 2015
Two things that concern me. Small generators run at about 50%, so at 3KW you will need a good airflow to keep it cool. The other thing is that it looks quite narrow, does it have two bearings on the shaft?
Especially with a single jet I would imagine there are quite large out-of-balance forces on the shaft.
Maybe ask on otherpower.com
What power levels do you think you will be operating at?Edited by davef 2015-02-05
davef
Posted: 11:54pm 03 Feb 2015
Another issue is 1KW at 12Volts is a lot of current. Are you planning to put your batteries within a few metres of the generator?
trout
Posted: 11:42pm 04 Feb 2015
Hi dave the overheating should be kept under control by the ceramic magnets, not sure about the 1 or 2 bearing thang
Downwind
Posted: 12:46am 05 Feb 2015
So what is the temp range of the magnets??
As all magnets loose power with temperature.
I think your view is a little flawed, or perhaps wishful thinking.
Pete.
Sometimes it just works
