Local Time 03:38 04 Nov 2026 Privacy Policy
Forum Index : Windmills : Found a black coloured F@F rotor
brucedownunder2
Posted: 03:01pm 22 Aug 2015
hello , I have come across a black coloured F@P rotor. never seen one of this colour before.
Could anyone out there confirm if it,s different to the old grey coloured types. I can,t access it for a couple weeks and want to know it,s specs,if different from the older types..
Did F&P ever bring out a Neo magnet type rotor??.
Bruce.
Bushboy
DaveP68
Posted: 01:31am 15 Sep 2015
Hi Bruce
These Black rotor caps can only be used on the 36 pole stators not the older versions.
They provide a 40% increase in output power for the same RPM as the strength of the magnets is greater. But the minor down side is they have a higher starting force.
The white arrow head rotor caps are hard to beat on a decogged 36 pole stator.
Hope this info answers you question.
David
There are realities if you do not accept, will lead to frustration because you will be spending time on wrong assumptions and the results cannot follow! The Dunning Kruger Effect :)
brucedownunder2
Posted: 10:55am 15 Sep 2015
Thank You Dave, Would you know if the new stronger magnets are the ,Neo, types?.
Thanks ,Bruce..
Bushboy
Posted: 12:12pm 15 Sep 2015
Hey Bruce
If the black rotor is for the new 36 pole stators, and has stronger magnets, then it would make a great 7 phase conversion on a old 80 or 60 series.
