Local Time 13:40 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Wind Towers
imsmooth
Posted: 02:18am 20 Mar 2008
Would a 10m flagpole rated for a 3.7 square meter flag in 45 meter/sec winds be strong enough to hold a wind generator? I was planning on using one with 0.55m^2 prop area (combined area of all three propellers) and a prop diameter of 2.65m.
I was also thinking of using an aluminum tower that I saw at www.universaltowers.com. They are light and rated for stronger winds for a given square foot exposed sail.
GWatPE
Posted: 06:06am 20 Mar 2008
My thoughts are flag poles are good to fly flags from.
How heavy would the mill be? You may still need to use a gin pole and guy ropes to raise the mill. Flag poles usually bend somewhat in the wind. I would not want my mill to be on the top of a moving stick. I still have guys on a 100mm dia steel pole that is bolted in 2 places to my house. My mill is in a domestic location, so it is appropriate that the tower is really strong.
The question you have to ask is, What happens when the pole fails? 10m is quite a way for the mill to come down from.
cheers, Gordon.
become more energy aware
