Local Time 13:40 05 Nov 2026 Privacy Policy
Forum Index : Windmills : F&P crack repair
BjBlaster
Posted: 12:55pm 04 Apr 2008
Hi Guys I've been following this site for quite a while and thought it was time I posted! Anyway I have got my first F&P and set about getting the motor out, but noticed the fine cracks in the stator housing and was wondering what glue / epoxy / stuff you guys use to fill in the cracks to prevent further damage. I believe it's and 80 series by the badly wound coils.
Bj
Check out my projects here in:
Bj's Shed
brucedownunder2
Posted: 09:26pm 04 Apr 2008
Hi bJ ,, Don't worry ,they are there to let the water out .. Just joking,, no, they will do no harm ,most of mine have small cracks ,just make sure you apply varnish to the steel fingers and if you are real worried ,paint the plastic with some plastic paint..
and ,while you are at it , paint the outside rotor plastic ,this will help reduce any cracking as it's exposed to sunlight(do you get any of that where you live??)
Have fun and consider the new Neo magnet retrofit that IMSMOOTH is developing..seems to be much more power..
Bruce
Bushboy
Gill
Posted: 10:08am 05 Apr 2008
G'day Bj,
Bruce is right. Don't worry about the cracks. I believe they are made over time by the stresses of fast stopping and change of direction during the agitation cycle when washing. This does not occur when used as a wind generator so they will never get any worse, nor do they cause any problems when left well alone. Occasionally you'll see a stator with severe cracks and still this never effects their road-worthy-ness. So proceed with confidence.
Cheers Gill _Cairns, FNQ
BjBlaster
Posted: 01:39pm 05 Apr 2008
excellent :) thanks guys I'm onto it!
Bj's Shed
BjBlaster
Posted: 12:46pm 09 Apr 2008
Ok, I've started a page on F&P stuff on my site for the development of a vertical windmill (can't decide what type just yet) but it will have to be some sort of "urban compatible" type of savanious / lenz to get those nasty turbulent winds :)
Thanks for the inspiration - this forum is great!
My F & P page is here -> F & P stuffEdited by BjBlaster 2008-04-10
Bj's Shed
dwyer
Posted: 10:30pm 09 Apr 2008
Hi BjBlaster
good on youa l like your picture set for others to see the understanding "How to pull apart on F&P washing machine"
Dwyer the bushman
