Local Time 00:01 08 Aug 2026 Privacy Policy
Forum Index : Windmills : Plastic blades
adam666
Posted: 08:52am 01 Feb 2006
I have some LDPE plastic tube approx 400mm diam. that I was contemplating cutting up to make blades for an F+p turbine. they are just under 1m in length, 10-12mm thick.
just wondering:
a. can reasonable performance be acheived with these if shaped right?
b. does anyone have a template or similar I can scale to get the correct shape?
im familiar with how the edges need to be shaped but the only 'outline' I can see is the 'mini-mill' battery charger pvc template.
where should I start :)
cheers
Adam
Edited by adam666 2006-02-02
"to capitalize on windy wgtn" -excuse the pun :p
Posted: 01:58am 03 Feb 2006
If you visit http://www.fieldlines.com/ and search for zub woof, you will see stories about blades made by Zubby using plastic pipe. These should get you pointed in the right direction.
I've made a few blades with PVC pipe, They worked good, but it was all guess work.
adam666
Posted: 12:41pm 14 Feb 2006
Great, thanks Glenn!
Will post back once i get them flying :)
cheers
Adam
