Local Time 23:46 22 Oct 2026 Privacy Policy
Forum Index : Electronics : TEG Generators
Ronwend523
Posted: 06:49pm 18 Mar 2018
I started this question over in Windmills but it started down another road dealing with TEG generators. My idea has drifted to making a trickle charge system attached to an exhaust manifold on an air cooled engine. How many and what size TEGs would it take?
Phil23
Posted: 09:27pm 18 Mar 2018
Other thought that comes to mind on a different tangent;
What about CDI ignition?
An easy addition to a conventional distributor, with even the option of a 2nd backup unit.
Over here they mention a huge energy saving over conventional Kettering ignition, in which case you may be able to lower your current requirements to maybe one amp & use the 10 TEG's mentioned in the other thread.
Phil.
Madness
Posted: 09:37pm 18 Mar 2018
In 1946 in the Soviet Union they had TEG radios power by a kerosene lamp.
Posted: 08:38am 19 Mar 2018
The solar panel idea that someone else came up with might be worth a look too as a second power source.
There are "flexible " film solar panels available that might conform pretty well with your upper wing shape.
Phil23
Posted: 09:01am 19 Mar 2018
  Warpspeed said   The solar panel idea that someone else came up with might be worth a look too as a second power source.
That one is in my head too.
That & CDI to reduce power consumption.
Updated my boat motor from Points/Kettering years ago.
The old points served me fine with never a breakdown.
Just had to set the Dwell once or twice a season.
The Electronic (Non-CDI), Dissy had one module failure, that had us paddling home.
If you went CDI it would be easy enough to have 2 modules with little weight, so there's no frantically flapping of arms.
CDI, but keep the points. They work, and would be handling much reduced current.
Phil.
Phil23
Posted: 09:23am 19 Mar 2018
TEG's never entered my mind until a few months back when I saw these at Bunnings.
Anyone seen one in action?
