Local Time 18:09 22 Oct 2026 Privacy Policy
Forum Index : Electronics : 24v inverter power board
johnmc
Posted: 07:59am 22 May 2019
Good day All
I am building a 24v inverter, for the mobile use, which will be hard wired in the bus.
I would prefer a 48v system but the generation of 48 volts is a problem.
The nanoinverter control PCB, will be driving one of Madness's power boards.
The question is, will the powerboards totem pole power resistor (120 ohms 5w) need to
be replaced with a 60 ohm resistor and the zeener diode is also reduced to 15v?
Cheers john
johnmc
wiseguy
Posted: 11:13am 22 May 2019
Hi John, saw this and wondered if it may be of interest - needs a few secondary turns removed not sure of the VA you are chasing?
Cant offer much help with your query - not familiar enough with the Mad design to comment.
Cheers Mike
johnmc
Posted: 11:20am 22 May 2019
Thanks Mike ,
I have built a 2 core inspire toroidal transformer for my 24v transformer.
cheers john
johnmc
renewableMark
Posted: 12:21pm 22 May 2019
Poida runs a test setup on his bench from 24v. (with the nano and Mad power board)
Can't remember what he changed but it wasn't a lot.
Give him a PM, I'm sure he'll set you on the right path.Edited by renewableMark 2019-05-23
Cheers Caveman Mark
Off grid eastern Melb
