Local Time 18:34 21 Oct 2026 Privacy Policy
Forum Index : Electronics : Power Inverter Plans
ArcticCat
Posted: 03:33am 26 Jul 2008
Anyone have plans for power inverters? Id like to know how to build one.
Ken
oztules
Posted: 10:38am 26 Jul 2008
What topology are you after, and what sort of power range.
There are plenty of smaller inverters around for less than the price of the box to put them in. Just to get a decent box built will cost more than a 300 watt unit.
.........oztules
ArcticCat
Posted: 12:36pm 26 Jul 2008
I'm looking for 12v inverter plans. As for the resources to build it, I'm not worried about, I just want to know what it takes to build one. This is not a cost savings project.
So, is there any DIY inverter plans floating around?
Thanks,
KenEdited by ArcticCat 2008-07-27
dwyer
Posted: 02:05pm 26 Jul 2008
look mate
There one that l found less in two mins on webs site
www.electronics-lab.com 500watts low cost 12volts to 220V inverter by author Ashad Mustifa and there are lot more on unless you try and find on webs site is start looking
Dwyer the bushman
Posted: 11:22pm 26 Jul 2008
Hi Ken
I've built a couple of low power inverters using parts from my junk pile. Each one was only good for 300 watts max, was very inefficient and took several hours to build. These days you can buy an efficient 300 watt inverter for less than $100.
If you wanted to build a small inverter as a learning expierence, then as Dwyer says, use google to search for "inverter circuit diagram". But remember unless you have a pile of spare parts/junk, and a few free hours, this will cost you more than a bought one from your local electronics shop.
PS. Found this, its the link to a kit I used for one of my inverters. I used it to drive the final stage transistors and transformer from a old 600 watt UPS. It worked but maxed out at 300 watts.
linkEdited by Gizmo 2008-07-28
Dinges
Posted: 11:32am 27 Jul 2008
I agree with the others, it's hardly economically worthwhile to build a simple inverter yourself when old UPS-es are thrown out by the dozen every day and 'real' (mod. sine) inverters are in the 25-35 E price range.
But, I'll admit I have toyed with the idea in the past too. And it could still be a small, educative and practical project for someone new to the field.
Here's one design I found a while ago. Can't get more quick & dirty than this. Even no need for soldering. I haven't built it but it should work, at least it did for Harry:
http://web.telia.com/~u85920178/power/psu_inverter_01.htm
He claims to have it taken only 15 minutes to wire up.
This is just one example. A few minutes googling should turn up more than you could ever read.
Edited by Dinges 2008-07-28
