Local Time 14:43 22 Oct 2026 Privacy Policy
Forum Index : Electronics : China inverter board
BenandAmber
Posted: 09:14pm 22 Nov 2019
In the United States we have two legs of 110 (120) volts a neutral and a ground
The electric companies high-voltage line is fed to a large Transformer on a utility pole
that Transformer has a center tap on the low side( the side that goes to customers disconnect)
that's Center tap( neutral) enables two legs of 110 volts(120) or 220 volts(240)
All most everything in the average American home runs off 110 volts
Exceptions are clothes dryer, hot water tank, cook stove, and central air these run on 220 volts
I have set all of my inverters up as hundred and ten volts up to this point
In the future if I set a China board
(or Nano) up for 220 how would that affect the voltage feedback
Especially when using 110 volts off of one side of the Transformer
I just can't wrap my head around how that would work
It seems to me like the voltage feedback wouldn't read  right when using 110 volts
Any information on this subject would be greatly appreciated
Posted: 10:07pm 22 Nov 2019
Just wind the transformer for your inverter with a 220v secondary with a centre tap.
It will work exactly the same as the pole transformer out in the street.
You can connect the voltage feedback across EITHER the whole secondary (220v) or half of the secondary (110v) and it will work fine either way.
BenandAmber
Posted: 12:00am 23 Nov 2019
Thank you warpspeed I appreciate it
I guess I was trying to over think it
BenandAmber
Posted: 05:51pm 23 Nov 2019
Warpspeed if you ever get a little extra time could you explain why this works
I know it is true because you said it
I have zero doubt after your response
I'm still having a little bit of a hard time wrapping my head around it
why if the voltage goes down on one side of the Transformer it goes down on the other
If flux is the right word I think it goes down equally throughout the core no matter which side is drawing the load
And another thing that is really bothering me that would really like a answer on
I honestly think a Transformer that is stacked higher instead of wider works a lot better
Longer part of the wire going through the hole on a taller one
Thanks again warpspeed
Edited 2019-11-25 00:13 by BenandAmber
