Local Time 19:43 21 Oct 2026 Privacy Policy
Forum Index : Electronics : Sanity Check
piercy007
Posted: 07:06pm 17 Aug 2008
Just a quick sanity check question.
If using a DC motor as a generator it should output DC (rather than AC). Therefore there is no need to rectify the current before it goes to the battery?
Also what would happen to DC if you did run it through a rectifier - does it have any effect?
cheers
My middle name is luck mind you my first is bad!
Haxby
Posted: 05:54am 18 Aug 2008
yes, you will get DC.
If you run it through a rectifier you will lose a bit of voltage due to the diode drop. Around 1.5V due to there being two diodes conducting. But it won't break.
Robb
Posted: 07:07am 18 Aug 2008
Use 1 diode or it will "motor" when the wind drops.
Posted: 07:32am 18 Aug 2008
Good point Rob.
