Local Time 11:36 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Power jack mosfets
Ramedtor
Posted: 10:50am 07 Dec 2020
Hello, I have a 15k power jack, all the mosfets had been damaged, I bought them all and also installed ALL the boards, again the mosfets on the positive side burned, I don't know the reason, my question is: those mosfets are installed in  a specific order?  is that I saw a different solder on some of them below, like a joint, or are they put anywhere?  mine is 24v 6 pcs.
BenandAmber
Posted: 08:36am 08 Dec 2020
did you replace the driver board
some times it blows when your mosfets blow it blows also
Genetry Solar will very soon have a upgrade kit for power jack inverters
many videos on PJ inverters on the genetry solar channel on youtube also videos on the new GS inverters and upgrade kit
it kit includes a  wi-fi and control board
you can see and make changes from your phone on other side of the world
with this kit you can set amps to charge your battery bank
hook two or more inverters together for higher wattage
you can hook three together for any three phase voltage
it measures two legs for output wattage
it has several pwn cooling fan output that you can set at any temp and ramp up speed with temp
has several temp inputs
both wi-fi and control board are new design and new programing
the mosfet drivers seem unblowable
this kit will blow your mind you can set anything to your needs
It can do so much more than i have wrote here
Every thing above is not even a drop in the bucket
I have been tenkering with many differant transformer designs and low side primary voltages
i haven't been able to blow mosfet drivers wi fi or any part of the control board
it is tough and very well designed!!
the benandamber mosfet boards kent designed seem to work well with them also
if you end up having to buy new boards i would recomend upgrade to the genetry solar
kit even if i had to wait for it
if you need a hole new control board and cant wait for the GS kit
i seen the 10.3 PJ control board on ebay for i think 120 bucks
i think it is the best of all the PJ control boards
I am just a jack leg that likes to goof the guys on here are some of the best in the world
Give it a little time make your setup and question as clear as possible with as much info as possible and one of the pros most likley will chime in
Edited 2020-12-08 19:10 by BenandAmber
