Local Time 20:45 21 Oct 2026 Privacy Policy
Forum Index : Electronics : 12v motor is it worth it
frank133
Posted: 08:36am 24 Sep 2008
Hi guys,I have my small turbine up and turning ,
The dynamo connected is not affective,
So I have been trying a smaller windshield wiper motor.
I have welded a pulley on the shaft,and have got a few fan belts to drive it.
On testing with a electric drill ,It only puts out 5v 1 amp.
I was thinking of using two motors wired together,
but I still dont know if I will get enough power to charge a set of batteries.
should I scrap this idea and look for a better motor,
thanks frank
Robb
Posted: 08:51am 24 Sep 2008
A motor with a bigger diameter designed for lower RPM use. would be better
frank133
Posted: 09:55am 24 Sep 2008
Thanks Robb,
I was going to run two of these together,but probably not a good idea,
I will have a look around for somthing bigger
cheers frank
